Like Tree5Likes
  • 5 Post By Aussie Mike
Old 07-06-2015, 03:05 AM
Default Wheel spacers
I have a set of 17" Halibrand replica wheels in 5 stud Ford pattern (9" and 10.5"), which were supposed to be for use on a Daytona Coupe.
The fronts require a 5mm spacer to clear the caliper and the rears apparently use a 25 - 32mm bolt on spacer to get the tyre sufficiently outboard so that its sits close to the guard.
Am advise that wheel spacers of any description are not legal for rego in NSW (not sure whether its the same in other States) AND that as they are a single piece cast wheel the Halibrands are unable to be altered.
Look forward to any advice on this one.. !
Second issue. Am knocking up a small 8 segment LED box for the dash warning lights but cant locate the official library of DIN spec images in order to get a transparency printed..??
Thanks in anticipation..
Chris
