Like Tree5Likes
Old 08-16-2015, 05:48 PM
Default 315 to 335 35 R17 tyres - Sydney
Am having no luck with treads for my Coupe as I try to get it to gokart stage.
Have seen a post in the Nationals forum re some 315 - KU36 coming to AU inside the next 4-6 weeks.
Can get Nitto NTO5's for the front (275/40/R17) easy enough.. but NOTHING for the rear...in any brand.
Called Matthews / Tempe and a couple of locals with no joy.
Look forward to any leads or suggestions.
With thanks
Chris
Old 08-16-2015, 05:57 PM
gjkrv8's Avatar
Try ITT - International Tyre Trader (on ebay too) - for KU36's
cheers
gregg
Old 08-16-2015, 06:18 PM
thanks Greg,
Will give them a go.. (edit - they have the KU36)
A number of the dealers are advising the 17's in the required widths are being discontinued.Any thoughts on whether it would be better switch to 18's at this stage ..?
Chris
Old 08-16-2015, 06:52 PM
leroy17's Avatar
How about TireRack in the USA. Have both KU36 and R888.
Sizes in stock, price with exchange is not overly bad (sure its been better in the past, but when you need something, its an alternative). And you will most likely have these within 6-8 days
http://www.tirerack.com/tires/TireSe...r=17&zip-code=
Old 08-16-2015, 07:50 PM
give phil a call he is here in sa but he deals just in motosport tyres mainly hoosiers but has other brands as well.
Lonsdale Competition Tyres, Adelaide, South Australia
cheers dean
Old 08-16-2015, 08:49 PM
scootter's Avatar
These are the only 335/17 left that I could find. Everything else is discontinued!! Michelin's.
Scott
Old 08-16-2015, 10:05 PM
albanycobra's Avatar
PHAT!!
Please post a pic from the rear when fitted
Old 08-17-2015, 03:55 AM
Thanks Gents,
Had advice a range of 17" treads have been discontinued as well, which will only make them harder to get over time.
Am thinking I should swap to 18" at this point of the build fix the front and rear offset issues and put the 17" Halibrands back up for sale.
Chris
Old 08-17-2015, 07:13 AM
Krait's Avatar
Tire Rack are only listing Michelins in 335/35/17.
Geoff
Old 08-17-2015, 11:08 AM
scootter's Avatar
I bought mine off tire rack. Had them in 4 days!! Pricey, but I was shocked how well they hook up!!!
Scott
Old 08-17-2015, 03:11 PM
hi Scooter..
Found a set of sumitomo's in 315 rear but they dont seem to do delivery to Australia... ?
Old 08-17-2015, 03:14 PM
scootter's Avatar
Tire Rack doesn't deliver there?
Old 08-17-2015, 04:23 PM
I cant get an option to edit the delivery fields and the site only accepts US post codes and cities
Old 08-17-2015, 04:25 PM
leroy17's Avatar
Originally Posted by SydneyChris View Post
hi Scooter..
TireRack will deliver to Australia, you need to contact them and they will work out a cost with FedEx.
For what its worth, my suggestion is to steer away from the Sumo 315's. They measure smaller and depending on the rim size that you are looking for these to go on, these may not measure up.
Have a google search and you will come across examples and especially compared to a Goodyear GSD3.
I am not being critical for the Sumo 315's for all the owners out there, however I am saying not all numbers are the same.
I had GSD3 (285 40 17) on my previous car with 10.75inch rims, this gave a nice square sidewall and was good to drive with.
315's Goodyear vs. Nitto - a Ghost4you Research Project...
275/40R17 who makes the widest?
Old 08-17-2015, 05:27 PM
thanks Leroy...
Noted re Tyre Rack.. they dont have an email contact option.. only email a friend.. ! lol.. then the Support line is open to suit the US time zone.
(ITT are now out of stock last check for the KU36 as well.. !)
If the Sumo's arent highly recommended it seems its better to change out to 18" rims and get a more readily available selection.
Chris
Old 08-17-2015, 05:45 PM
Aussie Mike's Avatar
Get on the phone to tirerack. That's the easiest way to deal with them from Australia. I've bought several sets of tyres from them.
I've also bought from International Tyre Trader in Australia and had good dealings with them
http://www.tyretrader.com.au
They are showing the KU36 in 315/35/17 to be in stock and only $300 each
Search
Mike Murphy
Melbourne Australia
Old 08-17-2015, 06:04 PM
Ordered.. thanks Mike... they werent showing first thing this morning.
Chris
Old 08-19-2015, 03:30 AM
Cobra Make, Engine: Harrison build #98 with Supercharged 6.2L of Chev Power, TKO600 5 speed gearbox
I got a set of Pirelli's from tirerack for another car. Great service.
They were out of stock at the time, I told them I want 2 front and 2 rear and a few months later got an email saying that they had put aside a set for me and did I want to go ahead. I went yes and 7 days later they rocked up at my door.
I run the KU36 in 315/35/17 on the rear. Seems a bit bad if I can't get this anymore.
Old 08-20-2015, 09:30 PM
scootter's Avatar
albanycobra, LoBelly and ICCARS like this.
Old 08-21-2015, 01:13 AM
I waited 15 months to get some KU36's in 315. Got sick of waiting.
Ended up fitting 285 as interim as thats all they could get at the time.
The 315 is the correct width for my rim and would be bad if I cant get them at all.
Ross
