Like Tree4Likes
  • 1 Post By deano59
  • 1 Post By leroy17
  • 2 Post By Mrs flatchat
Old 12-08-2015, 05:59 PM
snakesaway's Avatar
Cobra Make, Engine: Evans and Wooley, 302 Windsor, Supra turbo 5sp
Default Wheel PCD confusion please help?
Hi all,
I want to order some ET wheels AC-III 17 inch for my Evans running jag hubs front and rear. My 2 front wheels on the car have manufacturer labels saying they are 5/114.3mm PCD. One of the back wheels says 5/4.75. I have measured the PCD using the following method, http://www.etmags.com/pdf_download_d...rn_diagram.pdf, and I get 114.3mm. I looked at the chart on the worksheet and the PCD closest to this is 4.75" or 114.74mm .54 mm larger to my mind this would make quite a big difference overall. I am lead to believe by ET wheels that the standard Jag PCD in 114.74mm or 4.75". I can't find this information on the web any where. Every time I search for this info I get a PCD of 120.6 mm. So I am suitably confused as to what PCD I should be ordering.
Any help would greatly appreciated.
Andrew
