Like Tree19Likes
Old 02-15-2016, 10:48 PM
CHANMADD's Avatar
Lexan...Lexan......Lexan..........I've had a Lexan windshield for 25 years......beside the scratches I put in it it's still quite clear.....
deano59 and joyridin' like this.
Old 02-16-2016, 03:48 PM
joyridin''s Avatar
Agreed. I can't imagine why anyone would go with glass. Get some M10 Lexan, have then routered for $40, and you are set for years. You can even get them in different tint colors to match your wind wings if you desire.
Old 02-16-2016, 04:16 PM
Tim7139's Avatar
Cobra Make, Engine: Superformance #2660, FE-406
Not for nothing but you can bring them back to close to new.
5-6 sheets of wet/dry paper from about 600 to 3000 grit, sand each side wet. After the fine paper, go with a quality plastic polish like Novus and a soft cloth and they clear right up.
If you have no big surface scratches Novus makes a kit with 3 grades of polish and cloth for 10 bucks
The older I get, the faster I was.
Old 02-18-2016, 02:14 PM
Cobra Make, Engine: AC Adelaide, SVO 5l, Tremek 5Speed, jag front and rear
Just received my sun visor and wind wing hardware kits from Finish Line, fantastic service and quality . Recommend them.
Just a comment on Lexan , in some states in Australia you can only use laminated automotive glass for side wings and it has to have manufacturers stamp or etch to pass rego inspection.
SVO
Old 02-18-2016, 03:58 PM
TheExtreme's Avatar
Cobra Make, Engine: CMC #437, 408ci
Just had a set of visors and wind wings cut from one of my local shops. 1/4" grey tinted lexan. $80. I still need to do a little cleaning and polishing on edges.
Scott
Old 02-18-2016, 05:55 PM
Sorry to mention it again. But I find if you have the hinge bracket on the inside, then when you fold the wind wing to the inside then the hinge touches the frame, not the glass, when the bracket is on the outside.
Mine is laminated, but I like the idea of lexen so its lighter and less likely to break.
jd
Old 02-18-2016, 11:39 PM
albanycobra's Avatar
I'm thinking glass is the go Pace have glass wind wings listed as an upgrade
Old 03-08-2016, 02:40 AM
Tenrocca's Avatar
Looks like my work is buying a laser cutter....no prize for guessing what the first job will be
deano59, boxhead and Modena like this.
