Like Tree4Likes
  • 4 Post By Tenrocca
Old 04-11-2016, 05:46 AM
Cobrakiller's Avatar
Default Second O2 Sensor
I see some exhaust systems use a second O2 sensor after the cat. I am using a VF Commodore Ls3 engine and wonder if it is needed for IM240 emissions testing. The Vf does run a second one so do I leave it as per factory setup?
Old 04-11-2016, 06:16 AM
Tenrocca's Avatar
Not necessary. Only there to check your cats are OK. Doesn't affect emissions as such. Don't install and turn off in tune. Cheers
Gav, gjkrv8, Modena and 1 others like this.
Old 04-12-2016, 02:46 AM
Am running the same configuration.. you only need the pre cat pair. Get your ECU tuner to delete the second set of sensors from the scan so you dont get MIL codes / light popping up every time you start up.
Chris
FFR Coupe 65
LS3 motor, TR6060 box with Falcon ABS, 17" Halibrand wheels, 3.55:1 Ford Racing IRS and Willwood brake upgrade
Old 04-12-2016, 04:47 AM
Thanks for the reply's guys.
