Old 05-09-2016, 02:23 AM
Registered User
Default MotecM84 Coil packs and Cam/crank wiring
Hi All
I have a ford 5L from an AU falcon in Australia. I think it is a similar motor to the last ford Explorer motor from the US.
I'm also using a Motec M84 ECU.
It has the 4 coil packs which are 3 wire plugs so how do I wire them. Do I wire Ign 1 to run coils 1 and 2 then wire ign 2 to run 3 and 4 etc.
Both the cam and crank plugs are 2 wire plugs, so I am assuming they are magnetic sensors not Hall effect. So do I then wire these with only + and - wires and the shield to -ve with no sync or ref wires?
Any help appreciated.
Thanks in advance
Patto
Old 05-09-2016, 02:51 AM
Patto, have you tried going to the Motec website mate. You'll most likely find all the info you want there, or at least contact details so you can ask questions.
Rog 246
Harrison #100
Old 05-09-2016, 02:57 AM
Registered User
Yep
Sure have.
Been on there all day and gradually getting closer to the answer. Just thought I would ask some experts out there.
