Like Tree3Likes
  • 2 Post By Rog246
  • 1 Post By Modena
Old 07-20-2016, 06:40 PM
Default Ignition Issues
Guy's,
My Cobra has had cold start issues for a while now, lots of cranking
and running like a dog until its warm, then it runs and starts normally.
I have been away for a few weeks and wanted to sort the Cobra out
before the next run. I charged the battery on Saturday and tried to start the
car on Sunday. It cranked for a while and started but then stopped. It cranked
again then smoke came out and it wouldnt fire. I called the RACV and while I
was waiting the coil exploded. He replaced the coil and said it was dizzy
related. He put a long stick with a wodden end onto the dizzy and made it
spark, so he said it was one of the sensors in the Scorcher dizzy. I dropped
the dizzy to Scorcher and they are saying it is OK, it is 18 years old so they
are giving it a birthday. So where to from here????
I am running an MSD and MOTEC M48 also.
Could it be the MSD? or a switch ?? NFI
STIFFY
Old 07-20-2016, 06:58 PM
albanycobra's Avatar
check your ignition modules as well. Maybe just replace them if they are 18 years old. Do the usual checks like voltage when cranking cold, earths, plug connections , plug leads and plugs. Ignition components normally play up when hot not cold. Do a compression test as well.
Old 07-20-2016, 07:12 PM
Gaz64's Avatar
Out of Scorcher, MSD, and Motec, my bet is the MSD component is the culprit.
Old 07-20-2016, 08:53 PM
ICCARS's Avatar
Cobra Make, Engine: AC Cobra - ICCARS 001, 4.2LTwin Turbo, AWD, 5 speed tiptronic under construction
it sounds to me like you are running extremely rich on start up, so what I would do if it was me is to pull a plug or two and see what your engine is doing i.e. black plugs - rich as hell // clean or slightly greyish plugs OK. Then while you have the plugs out test for a good spark - that will eliminate the MSD.
It almost sounds like you have a change in state in the M48 - I have seen this happen with my M800 as a short or something like that can cause the program to corrupt - it has happened to me and I had to re-load the program and it was all good again.. Computers.
I'm not suggesting you do this at this stage, but keep that in the back of your mind if all else fails, but just keep eliminating every possibility one by one, not 2-3 things at once otherwise you may never find the culprit.
Wil
Wil Escabache
ICCARS AC Cobra 001 (AWD) U/C
RF 098 GT40 Twin Turbo
ICCARS GT40 - U/C
www.iccars.net
Old 07-20-2016, 08:58 PM
ICCARS's Avatar
Originally Posted by stiffy View Post
"I called the RACV and while I
was waiting the coil exploded."
STIFFY
Can I ask a question mate :- did you leave the ignition on while you were waiting for the RACV - LOL
Wil Escabache
ICCARS GT40 - U/C
www.iccars.net
Old 07-20-2016, 09:46 PM
Default Coil
Will,
No, I disconnect the battery charger also.
I just happened to touch the coil and noticed it was hot, and getting hotter.
The dizzy is ready so I can refit it in Saturday, I have an MSD
In another car so I can test this also.
Stiffy
Old 07-21-2016, 04:16 AM
ICCARS's Avatar
Will,
Stiffy
I only ask as I had a good mate of mine take one of my 1975 P5 Ltd's to a car show some years ago now and he left the ignition on all day and killed the Coil - it was red hot when I got there; needless to say I had to trailer it home....
Just make sure you see a good spark - with an MSD you should see lightening bolts.
Wil Escabache
ICCARS GT40 - U/C
www.iccars.net
Old 07-21-2016, 05:36 PM
Default Coil
Guy's,
Well the saga continues, the dizzy could not be faulted, so they gave
it a 21st present and its all new again.
I am collecting a new 6A MSD today and will hopefully fit them
tomorrow.
Is there anyone around that has more mechanical knowledge and
a timimg light as i'm not confident in putting the dizzy back in the right spot.
The usual Beer and BBQ will apply.....
Stiffy
Old 07-22-2016, 02:46 AM
Modena's Avatar
you're supposed to mark it before you remove it stiff
Ben in AU
Old 07-22-2016, 04:33 AM
Struth.............if I tried that I reckon my Missus would get really pissed at me !
Gaz64 and dhs.buckley like this.
Rog 246
Harrison #100
Old 07-22-2016, 04:15 PM
Default Marks
Benny,
I did, but I don't think it was TDC, hence the timing light
And someone who knows what they are doing.
Stiffy
Old 07-22-2016, 04:28 PM
Modena's Avatar
doesn't matter if it wasnt TDC so long as it goes back in the same spot, but yes a timing light to fine tune.
Gaz64 likes this.
Ben in AU
Old 07-22-2016, 10:08 PM
Gaz64's Avatar
Benny,
Stiffy
You must have a mate down your way to help.
I have a good timing light.
Old 07-23-2016, 01:12 AM
Default Spark
Guys,
We replaced the coil for the correct MSD compatable unit, replaced the
MSD and installed the dizzy.
It flattened the battery big time on initial crank then it killed the battery.
We hooked up another, it cranked but still no spark.
So back to the drawing board tomorrow.
Thanks Ben and LoBelly for their assistance today as it's way out of my
Comfort zone.
Stiffy
Old 07-23-2016, 03:13 AM
Gaz64's Avatar
Have you got a circuit drawing for how it all works on your car?
AS far as spark is concerned, is the distributor locked out (no advance), it then signals the MOTEC, the Motec then triggers the MSD module, is that correct?
Old 07-23-2016, 04:00 AM
The MSD likes 10volts or more or it won't fire under crank.
Often it will crank and crank then when you stop the crank it does a quick fire just before you turn the ignition off.
We have had lots of MSD blaster coils fail so have upgraded them to to E core.
There are numerous people having trouble with MSD products and are going back to basics.
If you battery is dead try it with the new battery.
Ross
Old 07-23-2016, 06:23 PM
ICCARS's Avatar
So from poor starting to no starting!!
I would be checking for poor earth connections as it seems as though it's a deteriorating condition that you have.
Wil Escabache
ICCARS GT40 - U/C
www.iccars.net
Old 07-26-2016, 09:00 PM
Modena's Avatar
Is that a 408 rumbling I can hear?????????
Ben in AU
Old 07-27-2016, 04:26 AM
Default 377 Actually
Benny,
It started, warmed up but then it wouldn't run so I couldn't
Adjust the timing with the light.
So I cleaned it instead.....
Today is another day.......
Stiffy
