Like Tree2Likes
  • 2 Post By Tenrocca
Old 09-24-2016, 07:34 AM
Gav's Avatar
Gav Gav is offline
Default Tremec plugs
Hi all,
I am fitting a 6 speed in the Daytona and have a loom for the engine that I've converted for it but it was an auto loom so is missing the reverse lockout and reverse light switch plugs.
Has anyone got surplus plugs that don't need or where would be a good place to snare a couple from?
Gav
Powered by Cu
Old 09-24-2016, 01:23 PM
PeterAllen's Avatar
Mal Woods Automotive, Qld.
I obtained a reverse light connector from him for a Mustang. It is a 90 degree fitting which is very handy is there is little clearance between the gearbox and the transmission tunnel.
Old 09-24-2016, 02:31 PM
Tenrocca's Avatar
https://www.eficonnection.com/home/S...ssSearchForm=+
Gav and gjkrv8 like this.
Old 09-24-2016, 03:20 PM
Hi Gav.. repeat re Mal Wood, however check your engine harness first though, the standard LS3 loom has the plugs for the Tremec for the lockout and speed sensor.
FFR Coupe 65
LS3 motor, TR6060 box with Falcon ABS, 17" Halibrand wheels, 3.55:1 Ford Racing IRS and Willwood brake upgrade
Old 09-24-2016, 05:26 PM
Gav's Avatar
Gav Gav is offline
It's an LS1 loom, so definitely doesn't have them.
Thanks for the heads up gents.
Powered by Cu
Old 10-06-2016, 05:23 AM
Gav's Avatar
Gav Gav is offline
The plugs turned up today from EFI connection, can't complain about their service!
Powered by Cu
