Like Tree5Likes
  • 1 Post By Three Peaks
  • 1 Post By Treeve
  • 1 Post By dave295
  • 1 Post By kyleb
  • 1 Post By Laner
Old 07-05-2018, 05:13 PM
Default 351w engine number
Imported 351w crate engine from US, trying to find out where engine number is located (if it has one) for rego purposes. Found casting number which indicates - 1994 bulid, most likely out of F series/Bronco
Any help appreciated
I dont have a temper,I just react quickly to Bull*
Old 07-05-2018, 05:44 PM
They are supposed to be on the flat machined part of the block behind the head, usually above the starter if I remember correctly. However, if the block has been machined it probably will be missing from that location.
Do a search on google for "351W number locations". Lots of info from different sites and forums...
mudbrick likes this.
Old 07-05-2018, 07:15 PM
Cobra Make, Engine: Dax
Being a crate motor it may not have one.
Each state and territory is slightly different here, but as long as you have proof of purchase, getting an engine number issued to you is very simple.
Treeve
Old 07-06-2018, 12:15 AM
Cobra Make, Engine: Evans chassis, jag fr. & rear.
On my 1990 F250 351W the number is on the front face of the block.
Above the water pump, on (Aust) drivers side, below the head.
Dave
Old 07-06-2018, 02:39 AM
Cobra Make, Engine: Robnell Blown LS1
My 69 Mach 1 has a 351w with the engine number on the R/H side of the water pump just below the head.
Old 09-24-2018, 12:45 AM
Laner's Avatar
Cobra Make, Engine: Pace 427sc 351w with TKO600.
i have a 351w crate motor in mine.
i had to get (well CW did) an engine number issued by the Qld cops.
i don't think it was much of a hassle tho.
certainly not for me anyway.
hope this helps.
"Life is hard, it's harder if you're stupid"
