Old 09-28-2018, 08:52 PM
Cobra Make, Engine: 6.2L LS3
Default Classic Revival square tube body removal ?
Hi Guys
Just wanted to remove the body from my Classic revival square tube Chassis (came fitted) Can anyone explain what the best way is to go about it ?
And the best way to store the body once off any weak points ? is on a flat surface fine or on saw horses ?
Michael
Old 09-29-2018, 07:49 AM
Gav's Avatar
Gav Gav is offline
Undo to the bolts and lift it off!
Nose up and lift it towards the back.
It should sit on a flat floor with no issues.
Powered by Cu
Old 09-30-2018, 08:12 PM
Tenrocca's Avatar
I think you have to lift the rear and slide it forward Gav. I know you tried to remove it sliding it backwards in the winton carpark.
Old 10-01-2018, 07:04 PM
Gav's Avatar
Gav Gav is offline
Double up
Powered by Cu
Old 10-01-2018, 07:06 PM
Gav's Avatar
Gav Gav is offline
You are right on one point there Dave 😉
I forgot to undo the bolts at Winton...
The back does come up and it goes forward because of the bar between the two front openings.
Powered by Cu
