Old 12-29-2018, 11:32 PM
itempany's Avatar
Cobra Make, Engine: Drb, 302 Comp cam, Cobra Nationals 2001 and 2002
Default Torana front end DRB
Hope everyone had a great Christmas and going to have a better New Year. Going to get the front alignment checked in new year as quite light at high speed. Thinking of altering camber. What front end settings does everyone use on their torana front end Drb's?
Ian
Old 12-29-2018, 11:35 PM
Gaz64's Avatar
Is this the front end out of a Holden Torana Ian?
Old 12-30-2018, 01:29 AM
itempany's Avatar
Hey Gary
Yes front end pretty sure out of lc torana
Old 12-30-2018, 01:49 AM
Gaz64's Avatar
I'd say a whole combination of things.
What tyres front and rear?
Power steering or not?
What steering rack ratio, or turns lock to lock?
Old 12-30-2018, 01:39 PM
Mrs flatchat's Avatar
Wink
for DRB's -- most likely a LH, X or UC torana front end
Make sure all bushings and ball joints are in good nick
Check for cracks around ball joint of the lower control arm
Check wheel bearings
Then go for a wheel alignment
Old 12-30-2018, 02:42 PM
Gaz64's Avatar
Yes, I would have though LH/LX before LC.
LC seems a bit narrow to me.
Old 01-08-2019, 11:42 AM
David Hodgson's Avatar
Ian, not sure of specific settings for yours, however you want to increase the caster a bit, not camber, to give it a bit more feel/stability at higher speeds. Too much and you run the risk of making it heavy at low speeds
SLIPRY
Old 01-14-2019, 10:21 PM
itempany's Avatar
Thanks for the replies. have been down Gold Coast for couple days. Will check front end when I get time.
