Old 10-05-2002, 12:54 AM
347's Avatar
347 347 is offline
Cobra Make, Engine: .
Default cam?
i have a 347 with 10.1 comp,quad 44 idf webers, windsor snr alloys,int flow 298 @ .600 , 309@ .700, exh 200 @ .600 209 @.700 ,4.1 diff ,tremmec
im currently running a solid flat cam 294 adv 248 @.050 560lift 110 lobes,can anbody suggest a another solid flat cam that could give me more upper rpm??
Old 11-26-2002, 06:39 AM
Cobra Make, Engine: Currently Researching
Just increase the duration to shift the rev range up higher.
Recommend you talk to your engine shop - the whole engine needs to match the cams profile otherwise it will be a dog.
