Old 08-31-2003, 02:44 AM
347's Avatar
347 347 is offline
Cobra Make, Engine: .
Default fuel pressure
Today I was driving along happily until my car felt like it was developing a miss or flatspot
I stopped and had a look and noticed my fuel pressure reg bouncing around the 13 to 15 psi
Webers only require 3psi
Does anybody have any idea's as to why it did this?
Are they easy to pull apart?
Old 08-31-2003, 04:28 AM
boxhead's Avatar
If your pressure gauge was showing to high a pressure and I think from memory you have an electric fuel pump then I would say it is more likely a regulator at fault, not the carbies.
If your pump has a built in regulator then it may be your trouble, some external regulators are adjustable so maybe this is your problem, the carbies do nothing in as far as controlling fuel pressure
Cruising in 5th
