Old 02-01-2004, 11:59 PM
347's Avatar
347 347 is offline
Cobra Make, Engine: .
Default cam question
If I was to put a 351windsor cam into my 289/302 with adjusted firing order,timing etc would the performance be any different if I was to put in the same spec cam with 302 timing?
Old 02-02-2004, 03:28 AM
Bruce Edwards's Avatar
Cobra Make, Engine: Hunter with a 4.6 supercharged
If the cam profile is the same you will not see any change. Ford changed the firing order because of a crank flex issue on the larger engine when the 289-302 firing order was used.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
