Old 06-19-2004, 02:31 AM
347's Avatar
347 347 is offline
Cobra Make, Engine: .
Default make me an offer
World products alloy windsor snr heads,quad 44mm idf webers,k&N air cleaners and manifold(both ported by Rams head service,have flow sheets)
Heads have isky double springs and damper(Spings are to suit a .560 lift cam) yella terra platinum shaft roller rockers,manley stainless valves(2.02,1.6)
Old 06-19-2004, 05:22 AM
750hp's Avatar
Are you looking to sell everything together, or will you separate.
Can you post a photo of the flow sheet for the heads? If not - could you please tell me the flow numbers for .500 and .600" lift @ 28" H2O. (inlet and exhaust)
I might know someone interested in the heads. Could you please PM or email an idea of what you're looking to get back from the heads?
Thanks !
Craig
Old 06-19-2004, 04:31 PM
347's Avatar
347 347 is offline
Off the top of my head inlet .500 lift 275cfm, .600 298cfm, .700 309cfm.....212cc intake runners 63cc combustion chambers.
I can fax them to you on monday if you like?
Old 06-20-2004, 08:48 AM
Aussie Mike's Avatar
Craig, Thinking about breathing more life into the Cobra or an upgrade for the Ute?
Mike Murphy
Melbourne Australia
Old 06-22-2004, 02:47 AM
750hp's Avatar
Mike - The ute's definitely not a performance proposition as it sits. I can definitely see a KB/Whipple/Lysholm/Sprintex making it's way under the bonnet at some stage. Gotta look at other priorities at the moment. Still vehicles, just not the ute
When does the spending stop?!?
347 - PM on the way. Thanks.
Old 06-22-2004, 02:58 AM
750hp's Avatar
... or email - one of those little buttons !
Craig
