Old 09-03-2004, 05:49 AM
boxhead's Avatar
Default Question to Mando
Did I read somewhere that you had a Classic Revival brake pipe kit for sale?
If so will it roll up into a suitcase?
I just realised your in Adelaide. I thought you where in Melbourne.
Are you going to the Nationals?
Cruising in 5th
Old 09-04-2004, 11:08 PM
Mando's Avatar
Hi Boxhead,
I do have a CR brake pipe kit Im not going to use and I will be at the Nationals in October. See you there. Its sounds as though its going to be the best one yet!
Regards.
Mando
Old 09-05-2004, 05:30 AM
boxhead's Avatar
Is the kit the hard pipes from master cylinders with T pieces to front and rear wheels?
Is it for the dual master cylinder setup?
If the answers are yes then I will buy it from you at the nationals, as long as there is room in Mike's ute.
Also is it rolled up or all straight?
Cruising in 5th
Old 09-05-2004, 05:51 PM
Mando's Avatar
Hi Boxhead,
the kit is made up of straight hard pipe with threaded connections in different lenghts for each section. One runs from the M/C to the T bolted to the main right chassis rail. Two hard lines then go from the T to your flexible line on the R/H side, the other to the L/H side. The other runs from your other M/C to the T bolted to the chassis behind the diff. Your flexible lines then connect from the T to the calipers. Hope it makes sense. I will definitely be at the Nationals next month.
Regards.
Mando
Old 09-06-2004, 09:12 PM
boxhead's Avatar
I will buy it from you if you can take it to Melbourne or Goulburn.
Let me know so I can arrange to get it home to Alice Springs.
I am hopeing to bring it home when I fly back
Cruising in 5th
Old 09-06-2004, 09:16 PM
Mando's Avatar
No problem at all. I will bring the kit with me to Goulburn.
Regards.
Mando
