Old 10-14-2004, 12:26 AM
snaken's Avatar
Cobra Make, Engine: Homebush, Dodge Viper blue, white stripes, black traditional interior 347, AFR heads, Morrison injection, motec, T5, live axle, lead car Bathurst drivers parade 1999, 5.0L Cobra Nationals sprint title 2001
Question rear coil overs - spring rate
OK, I have a problem.
Two broken drive shaft uni's, and a broken gear box - bad news
Time to rip it all apart and line up the moving parts. I have a salisbury live axle, currently using 900 lb/in coil springs and Koni adjustables. New coil overs will be verticle.
The coil over springs tend to be in the 250, 350, 450 range ?????
The car weighs about 1050 kg, weight is roughly 50/50, diff is unsprung so sprung weight is about 230 - 240 kg per corner. I want the car to be stiff, for sprint days.
Anybody know how to calculate the correct spring weight for coil overs
Snaken
Well will be when I fix the shocks and get a new drive shaft and gearbox.
Old 10-14-2004, 02:01 AM
boxhead's Avatar
I dont know how to work it out but my car (still building) is a very similar weight (less unsprung) and my kit supplier recommended 500 lb springs each corner.
Cruising in 5th
Old 10-14-2004, 02:50 PM
pneall's Avatar
Snaken,
Talk to King springs. (07) 55396700. They are real helpful.
Phil
Old 10-14-2004, 04:01 PM
Shelby400's Avatar
Cobra Make, Engine: Homebush. Lexus quad cam V8, R154 Supra box. Oh what a feeling.
Snaken
Have you already done the coil over conversion to the Homebush? I am thinking of converting mine.
Brett
!!Its good to be stroked but i'd rather be blown!!
Proud member of the Bclub Central Coast chapter
Old 10-14-2004, 04:31 PM
snaken's Avatar
Talking Got the answers
Hi Brett,
I have found the answers.
Have just ordered from Summit Racing, QA1 coil over shocks ( part no. HAL DR4855B ) and 350 lb springs, mounting backets and adjustmnet tool, you can find them all at http://www.qa1.net/
Will pick them up in the US next week .........Ya Hoooo
Life is good.
Snaken
Old 10-14-2004, 05:10 PM
These spring rates sound about right for logging trucks, but for a Cobra?
Rear springs 180 - 220 #/" (street), 220 - 240 #/" (race).
Fronts are a little stiffer because the control arm acts as a lever on the spring. Load on wheel ~ 600#, load on spring ~ 900#.
350#/" for a small block, 500 #/" for a big block.
Old 10-14-2004, 05:41 PM
Aussie Mike's Avatar
Hi Pete,
Those QA1 col over look like a nice piece of kit. I've bought their Crome Molly rod ends in the past and they seem to be solid and well made. I was having a look at a pair of their shocks at MacDonald Bros Racing a while back. Billet alloy construction and a fairly solid looking shaft running through them. Bernie is running them on his Cobra.
Did you go for spherical ends or urethane?
Mike Murphy
Melbourne Australia
Old 10-14-2004, 06:52 PM
snaken's Avatar
Hi Mike,
I went for the spherical ends. Better for the track. The big 15 in road tryes I run at 15 to 18 lbs so that softens the ride on the road.
The 12 shock adjustments will be handy for easy adjustment. Probably need to re arrange the bump stops.
I got a bum steer with the old spring rates, they were more like 250 - 300 than the 900 advised.
The tech people at QA1 were very helpful.
Snaken
Old 10-14-2004, 09:51 PM
Talking Stiff is my middle name
Why didn't you contact me straight away Duncan......
The name say's it all...............
Old 10-14-2004, 09:58 PM
Default Re: Stiff is my middle name
That's not what that lady from the Goulburn Motor wreckers was saying when Pete and I were out there looking for parts for his broken Drivetrain.
Mike Murphy
Melbourne Australia
Old 10-14-2004, 11:28 PM
snaken's Avatar
Talking
I didn't go there, but she was kind enough to return my sunnies.
Very friendly and obliging people in Goulburn.
If I have chosen spring rates that are too hard, the vibration could have pleasant side effects
Snaken
Old 10-14-2004, 11:32 PM
pneall's Avatar
For who?
Phil
Old 10-16-2004, 03:27 PM
Leeroy's Avatar
I thought when driving a cobra a traveller was a given!!!
Old 10-17-2004, 09:56 PM
Thumbs up I did it for the Club
As a new member to the club I thought I should do i t for the team
I was pretty certain that at least one member of the group would
need her help over the weekend (I certainly didn't)
Old 10-17-2004, 10:06 PM
Jeez, So there is some truth to the rumor, I was just fishing.
Good on you for taking one for the team. That's what Cobra club membership is all about.
Mike Murphy
Melbourne Australia
