Old 11-28-2004, 07:29 PM
Alvin's Avatar
Cobra Make, Engine: DRB COBRA, 302W, GT40 manifold, E303 cam, Trickflow alloy heads, supra gearbox, LSD, commodore brakes, Autronic computer. The car was modified by Doug Pearce
Send a message via ICQ to Alvin
Default Hot Cobra !!!!!!!!!!!
Hey All
took the cobra for a drive on the weekend and realised with this hot weather my footbox is getting to hot and l was wondering what can l do to reduce the heat!!!! I've got exhaust wrap??????
What can l do!!!!!!!!
Alvin
akyong1@optusnet.com.au
Old 11-28-2004, 07:55 PM
PCC's Avatar
PCC PCC is offline
Alvin,
Had a similar problem with mine (exasperated with the QLD weather)
When I had the cockpit reupholstered took the opportunity to line the footwell with insulation matting.
Vastly improved things - now I have the soft feel of leather rubbing my left leg
Prior to having the matting fitted (which is easy enough to do yourself (cut it and stick it) I was thinking of insulating on the underneath are of the car, but did'nt need to
PCC (Peter Craig)
Keep the sun shining
Old 11-28-2004, 08:45 PM
pneall's Avatar
Alvin,
I glued thermal insulation( shiny aluminium /woven fabric) to 1.5 mm aluminium sheeting then attached this to engine side of footwells with 5mm air gap.
Seems to work OK.
Phil
Old 11-28-2004, 09:20 PM
Cobra Make, Engine: Currently Researching
Recommend never wrapping your exhaust. Depending on your tune it will most likely thermally fatigue the metal, and as well, it often becomes a rust trap.
Old 11-28-2004, 09:24 PM
PCC's Avatar
PCC PCC is offline
On a DRB 2000 with a EFI Windsor you have to wrap one of the header pipes (vertical section joined onto header) as very close to starter motor solenoid.
Far rather pay for a short length of exhaust than a new starter motor every year.
PCC (Peter Craig)
Old 11-28-2004, 09:31 PM
There is better solutions to the problem, like thermal barrier coatings.
Old 11-28-2004, 09:54 PM
Cameron Parsons's Avatar
You could always fit Air Conditioning.....
Just a moment while I adjust the placement of fingers in my ears for the replies
Cameron
Queensland Cobra Car Club
Wisconsin USA Chapter
ex: Beijing Chapter Member
Old 11-28-2004, 10:56 PM
Ant Ant is offline
Default Thermal problems
I have used Kawool, not sure how you spell it, but its white and a bit like fibreglass batts, quite dense will never burn, can be wrapped around a boiler stack etc.
I made an aircraft alloy firewall with 5mm stand off bobbins and fitted Kawool behind it - absolutely NO heat gets through....period!
Another way maybe a good fireproof silver side heat resistant material, that can be glued on and supported by alloy strips either riveted or whatever, like a lot of original Cobras have around the foot box.
A J. Newton
The 1960's rocked!
Old 11-29-2004, 12:04 AM
Phils idea has traditionally proved to be the best solution to the problem.
Exact same solution for those running under car cats...thermotec between the floor and an aluminium heat shield above the cats. Sure saves melting ya carpets, or the butt of ya passenger.
Old 11-29-2004, 05:23 AM
BMK's Avatar
BMK BMK is offline
Alvin
Ring John Cini.
He put me onto to a thermal company in Altona Melbourne. They supplied 2 m square of thermal blanket at under $100. As used in the refineries.
I used it under all of the aluminium and as a heat shield as mentioned above. I also glued it inside the upper guards and there is no heat there now.
Bernie
Bernie Knight
Old 11-29-2004, 06:32 AM
Alvin's Avatar
thanks for everyones ideas
Alvin
Alvin
Old 11-29-2004, 02:53 PM
BMK's Avatar
BMK BMK is offline
Alvin
Doug may have some laying around over there.
Bernie
Bernie Knight
Old 11-30-2004, 02:47 PM
justbetter's Avatar
Cobra Make, Engine: Superformance AUS002, Chev 5.7 with hairdryer
Thumbs up Superformance
FYI.
On the little old Superformance we have the front Air holes ( small oval grills left and right of the mouth ) plumbed up with a rubber boot that pipes cool out side air into the foot well, creates a nice breese amongst your feet and helps circulate the air in the cabin.
Check out Camerons car week after next.
Garrett
Garrett
COBTHS
Superformance SPF AUS002 "Modified"
Old 11-30-2004, 04:14 PM
FUNFER2's Avatar
DRY ICE !
Kevin
Old 11-30-2004, 08:31 PM
Cobra Make, Engine: Shelby CSX 4305 40th Anniversary #26 of 40 Limited Production Factory installed Stage 3 Supercharged 460 Stroker 858 HP
Send a message via AIM to Supersnake Send a message via Yahoo to Supersnake
Alvin, You might try powder coating headers. Should reduce engine compartment temp by 50 degrees.
Bill
Supersnake
Old 11-30-2004, 09:33 PM
Fitz's Avatar
Cobra Make, Engine: FFR Mk 3 408 530 - 585 T- mustang Dyno at B&R
Take a look at what I did. I sold a cobra that had a lot of heat coming out of the pedal area. I put a flash light down by the gas pedal and fixed the holes where light came though. It fixed the heat problem coming into the cock pit where wires came into the cock pit, steering column, under the dash etc. I also have air conditioning.
In the pictures of my new car in my gallery I put extra insulation padding behind everything surrounding the engine compartment. I also insulated under all the carpeting. You can check with Gordon Levy (480-446-8442) about the material. I hate the heat coming into the car and living in Phoenix when it is 115 you.....well you just die in the heat.
Fitz
fitzus1@gmail.com
Old 12-02-2004, 03:40 AM
Cobra Make, Engine: Classic Revival, LS1, Shift kitted auto, high stall, AU LSD rear.
I can supply 25mm Ceramic wool blanket as described by Ant and Bernie can be purchased by the 7.2mtr x 0.6mtr roll for $76.00+ frieght.
Anyone keen?
Gav
Old 12-02-2004, 07:31 AM
BMK's Avatar
BMK BMK is offline
Fitz
Just looked at your gallery. The Cobra looks good.
Thought the FFR body came attached to the frame..
I also insulated under the aluminium floor and footwells. Surprisingly cool. Have taken the shine off with WD40 and a scrub pad.
Gav Mildura.
Thats the stuff...
Bernie
Bernie Knight
