Old 06-27-2006, 10:10 PM
Cobra Make, Engine: Classic Revival 3506
Default I have a wheel problem
Hi guys has anyone with a CR fitted 15 x 8 with a 2 3/4 outside offset
and 5 1/4 inside offset with out them fowling ?
Also rear 15 x 10 with 2 3/4 outside and 7 1/4 inside offset ???
I have just got a beautiful set of Halibrand copies and they dont fit !!!!!!
Thanks Paul
Old 06-27-2006, 10:44 PM
Aussie Mike's Avatar
Is the inside edge of the front rim hitting on the tie rod end on the steering? This is close on a 17x8" rim with 5 1/2" back space. It'll be even closer with the smaller 15" rim.
The rear should clear. The only thing I can think of that might hit is the spring and this will depend on where your lower shock mount is located.
How about a couple of pics to show what the problem is.
Mike Murphy
Melbourne Australia
Old 06-27-2006, 10:48 PM
To gain additional clearance you could try doing a heim joint conversion and mounting the rod ends on top of the steering arms. I originally did this with plans for 9" wide front rims and to improve the bump steer (rather than dropping the rack).
Mike Murphy
Melbourne Australia
Old 06-28-2006, 06:53 PM
pneall's Avatar
Paul,
I think you need a support group meeting
Phil
Old 06-29-2006, 02:55 PM
Default wheel problems
Thanks Phil I think I need a cuddle
Old 06-29-2006, 03:21 PM
BMK's Avatar
BMK BMK is offline
Mmmm a group circle and admission.
Hi my name is Mike and I have a CR with an LS1...
Bernie Knight
Old 06-29-2006, 03:48 PM
Hey Uncle Mike.....that's a mighty glossy caliper you have there....what sorta paint is that?
And......
When you gonna get into CAD and build up a file to mill those calipers outta billet aluminium.
Would save about 6kg a wheel I reckon.
Back to the regular programing ....
Old 06-29-2006, 03:54 PM
PCC's Avatar
PCC PCC is offline
Hey Les...............
What gets me is how bloody shiny Mike's bits are - obviously hasn't been around yet
I think his paint must have been bought in the Valley - You often see quite a bit of red around there
PCC (Peter Craig)
Keep the sun shining
Old 06-29-2006, 04:05 PM
Yep, too many traffic lights in the valley Pete.
You were referring to the traffic lights were'nt you?
Old 06-29-2006, 04:12 PM
PCC's Avatar
PCC PCC is offline
No
The big red dragon of course
http://static.flickr.com/5/7754302_43017c4fab_m.jpg
PCC (Peter Craig)
Old 06-29-2006, 04:17 PM
[quote=PCC]No
A one eyed one no less.... I've heard about them.
Old 06-30-2006, 12:05 AM
hewey's Avatar
Cobra Make, Engine: CR LS-1 GEN III 5.7L V8
Mike - how do you keep all your bit's so shiny - even your tie rod ends are shiny !
Old 06-30-2006, 08:16 PM
boxhead's Avatar
Lotsa polishing I would say
Cruising in 5th
Old 07-03-2006, 03:32 AM
venom0427's Avatar
paul, i didnt know it was you, could you send me a pick of the rear caliper and i can put it into the mem bank venom0427@bmail.com.au.
also is it the brake or h/brake that hits???, please don't cry. david
