08-22-2006, 07:39 AM
Member of the north
Cobra Make, Engine: A Cobra
I can drowned a BASS thumper four cars up.
08-22-2006, 07:49 AM
VIC
Side vents
According to the age of my car the engineers report states that it had to comply to 98db but I think they are a bit more than that.
Here is a rough sketch of the internals of my side pipes.
I think the pipes must have had a lot of scourers stuffed in them for rego.
Bryan
VK3KDN
08-22-2006, 09:57 AM
Cobra Make, Engine: BDR 89 KEITH CRAFT ALL ALUMINUM 427 WINDSOR
Mine has 2'' tubes from heads to collector then has 3.5'' straight pipe from collector to sidepipe tip. Although she does have one of those vortech cone thingys in each pipe just behind the collector. Lets just say I can almost wake the dead a half mile from the graveyard.
DON
08-22-2006, 01:33 PM
HUH??? WHAT????
Seriously, wear some kind of hearing protection.
Cheers!
Dave
Dave
08-22-2006, 04:49 PM
Kanga, have a look at my gallery and it shows what they look like! Basically cutom headers into 4 into 1 collector then 4 inch external tube with 2 inch internal perforated tube with stainless and fibreglass matt surrround then back into 3 inch. I think? Straight through jobby... I am going to need to make a few small adjustments!
Spookypt
08-22-2006, 07:51 PM
NS
Cobra Make, Engine: Classic Revival, Gen3 ls1, Vortech T-Trim, Motec, tremec M12, wilwood brakes.
Just remember that it is not that bad getting done for being to loud by the establishment but getting court with no cat converters will seriously wreck you day!
Craig W
Central Coast NSW
08-22-2006, 08:17 PM
NSW
Cobra Make, Engine: Homebush. Lexus quad cam V8, R154 Supra box. Oh what a feeling.
I've heard fines of up to 10k may apply if your found not to have cat converters
 !!Its good to be stroked but i'd rather be blown!!
Proud member of the Bclub Central Coast chapter
08-22-2006, 08:49 PM
WA
For the minimal impact cats have on performance I think it's wise to run them. They do act as a muffler too, taking some of the "raspiness" out of the exhaust note, which to me is a bonus.
08-22-2006, 10:41 PM
ACT
Cobra Make, Engine: '85 Dax, 302W - "Street Boss", C4, Jag suspension
Under car with one muffler each side (look like standard old holden mufflers)
For rego transfer (18 months ago), needed to meet current regs - 90dB at 3000 revs measured 1m from tip. first try @ 95 dB - replaced mufflers (new, and in stock) then came in (out?) @ 89.9 dB - they laughed and were happy.
Burble almost disappears at 100kph (very easy for cruisin'), but sounds great when floored ....
...Ralph
30 year old car - a work in progress
08-22-2006, 10:59 PM
ACT
This was also mentioned over on one of the bowtie threads. In my experience with other guys, cats tend to 'mash' the noise and really help in achieving an acceptable level in side pipes.
Compression though is a real noise maker, and its difficult to quiten the 'bark' of a hi comp engine.
PhilM, is your new engine higher compression than previous?
SLIPRY
08-22-2006, 11:10 PM
NS
I am sure PhilM bank account was defiantly decompressed after paying for his new engine
Craig W
Central Coast NSW
08-23-2006, 01:53 AM
Qld
Compession
HI david,
Yes, the new engine is at 11.5:1, or close to that I do know that I asked to run on optimax fuel and we took that to the limit, and yes the exhaust note seams to be much more intense.
Craig,
If you compare what a good crate motor, like the efi Roush 347 the cost was reasonable, it is the cost of upgrading everthing else that gets you!!!
Glad it is nearly done, wallet is in intensive care, and the fake amniesia is wearing thin when fielding questions from the finance depatment.
Phil
08-24-2006, 06:42 AM
Zzz
Well I have Aussie Mike specials - I'm all whisper quiet... 90dB(ish) I can even hear myself think now!
Bernie Knight
08-25-2006, 07:07 AM
NSW
Originally Posted by REPTYL
When I had the side pipes running I did a little test down the south eastern freeway.
Held the sound meter at my right ear while doing 100 k/ph.
109db at my ear!!!!!!
Let’s just say I started wearing earplugs while driving the Cobra long distances.
The exhaust now exits out the back of the car and I must say it's much nicer that way.
When I had the car engineered for the first time it blew 102db at the tip.
It had to be 92db 4 inches from the tip at 45 degrees at 2/3 max revs.
To get it to that I ran duel inch and five eighths exhaust with 2 commodore mufflers, four resonators and two and a half metres of chook wire jammed up the tail pipes.
From memory it blew 98db with out the chook wire. (max revs dropped to 4 grand when the wire was added).
What ever it takes, right.
Ha Ha my car was so muffled through the temporary 2 into 1 system that the back pressure had to be removed with a vacuum cleaner before it would start. It only just passed because it made high pitched whistling noises that upset the decibel meter. A larger diameter pipe would have done the job !
08-25-2006, 02:06 PM
AUS
LOUD SIDE PIPES ARE SAFER...
As there is no temptation to use mobile phone will driving as you can't hear what the hell the other person is saying...although I suppose you could still text.
I remember cruising through the centre of the city here years ago in the old Cobra. Drove down one street and got stopped at the end at a set of lights, you could hear the car alarms wailing behind, in the mirror you could see the indicators/lights flashing on the cars I had passed, it was an amazing sight. Doesn't happen anywhere else, the tall buildings echo/enhance the noise.
