Old 10-27-2006, 03:53 AM
Cobra Make, Engine: DRB,Ford Tickford 302 220kw with BTR 4 speed auto, 3.9:1 LSD
Default help! hard top rear window
Can anybody help me. I'm going insane trying to fit the rear window. Seems like only an octopus could do it.
Cameron
Old 10-27-2006, 04:40 AM
Clois Harlan's Avatar
In the states we have a mobile window replacement service and I ended up calling the Glass Doctor to intsall mine. I fought it for two days before yielding to my wifes suggestion "Why don't you call someone that knows what they are doing before you tear something else up?".
The guy used dishwashing soap and a flat piece of plastic about 1" wide and maybe 1/16" thick x 8" long to work the Lexan into the rubber. It took him about 30 mins.
Clois
"Let's roll"
"Be part of Something Good
Old 10-27-2006, 05:35 AM
400TT's Avatar
Definitely good advice, call a mobile windscreen guy.
The only rear hardtop window I've seen fitted was by a windscreen guy.
www.absolutepace.com
Old 10-27-2006, 06:42 AM
nikbj68's Avatar
Cobra Make, Engine: Hawk 289FiA with Le Mans hardtop. AC CS(X)2131,289 (my father owned it from `67-`73)
At a a bodyshop I used to work in, we used washing-up liquid and garden strimmer 'blade' cable.
1.Fit seal to opening, insert strimmer cable into window recess, from bottom left corner, over the top & down right hand side.
2.Wipe around seal with soap.
3. Lay screen into the bottom lip of the seal, apply light pressure to the screen & pull the cable outwards at 30-45 degrees to direction of pull(easier with 2 people but can be done alone!), taking care not to pull on the length of the cable.
4. Stand back and say, "Wow.... how quick & easy was that?" I hope!
Nik.
"If I plagiarize, it's only because I like someone else's idea better than mine and I want credit for it."- Anna Sato-Williams.
"If I plagiarize, it's only because I like someone else's idea better than mine and I want credit for it."- nikbj68
Old 10-28-2006, 07:33 PM
Thanks for the advice folks. I think I'll be calling the professional. I have just finished making side windows for my hard top. I will submitt a post with construction pictures in the near future.
Cameron
Old 10-30-2006, 08:48 PM
BMK's Avatar
BMK BMK is offline
Cameron
Now just don't slam those doors or you will blow that rear window out...... Mmmm you think I'm joking..
Bernie Knight
