Old 02-03-2007, 03:38 PM
Cobra Make, Engine: DRB - 302, T5, VN Rear
Default DRB - Oil Filter touching subframe
Hi,
I am using the recommended Z10 oil filter (engine 302W) however it is touching the Torana subframe. I had to drop the back of the engine as far as it would go just to get it on, it then touches when I put the engine back to its normal position.
Is this normal ? Should I be looking at a remote filter setup or possibly an adaptor I have seen that turns the filter 90 degress to the front of the engine? With this adaptor however it looks like it will foul my mechanical fuel pump....
Dan
Old 02-03-2007, 03:58 PM
Philm's Avatar
Default Filters
HI Dan,
The 302 usully runs a Z9 filter. I had clearance problems with mine and have fitted a Z89A, similar to the Z9 but shorter.
Not a fan of remote mounting the filter, it is just more connections and more opportunity for leaks.
Phil
Old 02-03-2007, 04:15 PM
Hi Phil,
The z10 and z89 appear to be identical in size. Just checked the Ryco site and is says the z10 has been superceded by the z89a.
Looks like I need something about 10mm shorter or lift the engine up a fraction.
Old 02-03-2007, 04:27 PM
Blair's Avatar
Cobra Make, Engine: DRB Cobra, Ford 2001 4.6l Quad Cam Stroked to 5.2l (ported heads, reground cams from SHM + a Kenne Bell 2.8 Charger + Intercooler) Autronic SM4 Ecu, Autometer Cobalt Gauges, Trigo 8 & 10 x 15 Halibrand Knock Offs, Goodyear Eagle Tyres
Not to sure on your situation (torana & 302 + Z10) but my DRB with a 4.6 and a standard oil filter there was no way I could even put the oil filter on! Actually if you look closely in the attached pics even with a remote oil filter setup the torana 'sub frame' had to be notched so that under hard driving conditions the sub frame would not hit the remote setup.
Never Piss into the Wind!
Old 02-03-2007, 04:42 PM
WildBill3's Avatar
I think the remote idea is a good 1 if your carefull with the conections leaks wont happen.those nice an fittings are pricey but well worth the investment..
Old 02-03-2007, 04:51 PM
400TT's Avatar
Yeah, that's normal...on Torana based DRB's you've got to use the shorter filters. Z9 won't fit.
From memory we used to use a short Fram filter.
www.absolutepace.com
Old 02-03-2007, 05:47 PM
Philm's Avatar
Looks like a remote mount is the way to go, looks good Blair, that engine sure is a tight fit.
Phil
Old 02-03-2007, 09:43 PM
Cobra Make, Engine: DRB,Ford Tickford 302 220kw with BTR 4 speed auto, 3.9:1 LSD
Hi Dan,
Yesh.....I could not get my engine in with the filter on.
I went remote. The windsor has more room for the remote connection than Blairs Gigantor block so fitting is pretty easy. Whilst you are putting the remote filter in it is a good time to decide whether or not you are going to have an oil cooler.
Cameron
Old 02-03-2007, 10:16 PM
Gav's Avatar
Gav Gav is offline
Sounds like a perfectly good excuse to fit a LS1 to me
Powered by Cu
Old 02-03-2007, 10:49 PM
had the same problem, went with the remote setup never had a leak problem .
Old 02-04-2007, 02:09 AM
acecob's Avatar
Ive got a DRB running a remote filter set up.
works good had no problems.it's actually easier to change the filter
and its mounted inside the left hand gaurd.
Old 02-05-2007, 12:53 AM
Gav's Avatar
Gav Gav is offline
I feel as though I am being ignored
Powered by Cu
Old 02-05-2007, 02:47 AM
That's ok Gav, Torana front end is GM...... just like an LS1
