Old 04-21-2007, 06:46 AM
Default LS1 Harness
Help Needed Again
For those guys who have installed the LS1 motor /Harness
I have a connector with no home. It is a 2 wire plug with a blue half cover (no rubber seal) the wires are red and black, and red and white. The Wires exit the main harness almost inline with the bell housing and would reach about the shifter position or (back the other way) the starter motor. What sensor does this little bugger attach to??.
Old 04-21-2007, 07:04 AM
Found it. The plug goes to the throttle relaxer which I dont believe I have or need anyway. Does the LS1 Monaro 2004 have a throttle relaxer ?.There appears to be all the traction control circuit wiring in place but I dont intend using it.
Old 04-21-2007, 06:16 PM
boxhead's Avatar
I dont have the wiring diagram here but yes the Monaro would have had a throttle relaxer (part of the traction control)
Cruising in 5th
Old 04-22-2007, 05:57 AM
just found that plug it goes to throttle actuator motor
themotor sits on drivers side inner gaurd around the strut tower sort off
this motor has throttlecable coming in from pedal then another throttle cable out goin to the throttle body butterfly
not needed for yr application
my website
www.sideshowsperformancewiring.com.au
