Old 05-03-2007, 05:24 AM
Cobra Make, Engine: classic revival 302w
Default 8 TB Injection on ebay
Hey Guys,
I stumbled across these units if anybody is looking for some
http://cgi.ebay.com.au/Ford-Chev-Hol...QQcmdZViewItem
im sure the link is not ment that big
cheers
jess
Old 05-03-2007, 04:13 PM
boxhead's Avatar
Well that is exactly what I am lookingh at (after the car is on the road) I am a little scared as he has no feedback as a seller.
They look like a standard TPS would bolt straight onto the back of the throttle body, standard injectors.
Maybe some of the experts could tell us if fitted to a Gen III would the standard ecu handle this setup (I think it would) running mafless.
Looks like a pretty good price to me?
Cruising in 5th
Old 05-03-2007, 05:34 PM
The standard PCM will definitely run it, just some minor VE table changes would be about it. Decent valve springs (915's or 918's) would be a must too, just to take advantage of the top-end flow....
Old 05-03-2007, 07:51 PM
Based on the location, I think this is the same guy that supplied the Mizzi manifold.
Ben
Old 05-04-2007, 06:58 AM
Philm's Avatar
Default Dc&o
Yep, they are from DC&O at Ingleburn NSW.
The set ups are not bad, I did change the linkages to rod ends as I did have a 0.5% flutter on the throttle position.
There are a few companies that now sell them like injection perfection and Ziggy hotrods.
Don't know what is going on with the feedback but I do know that most of his production is exported to the US.
Phil
Old 05-04-2007, 07:13 AM
Tenrocca's Avatar
All the good stuff comes from out Campbelltown way .
RE him not having any sellers feedback, not really the kind of item anyone would hit the buy it now button on without asking a few questions first, and any seller if contacted direct would rather sell direct rather then send commision to ebay - I would consider it more a classified add to bring business in, rather then a actual auction\"buy in now".
Cheers.
Old 05-04-2007, 11:05 AM
pmfranke's Avatar
Cobra Make, Engine: B&B 351/402 Fi roller everything
how much is 3200.AU in US dollars ?
the older i get the faster i was.
Old 05-04-2007, 04:56 PM
$2656.00 approx
