05-08-2007, 04:04 AM
Vic
Cobra Make, Engine: Classic Revival LS1 6spd
Heater
Plums
Aussie Desert Coolers make a compact heater.
Its about 200mm x 200mm x 200mm square box.
Cost $250.00
They will post it to you, thats what they did with mine.
Rod
05-08-2007, 04:35 AM
Qld
Heater
05-08-2007, 05:28 AM
NSW
Plums,
I have one of the Aussie DC ones that I decided not to use.
$200 if you are keen.
Ben
05-08-2007, 05:52 AM
Vic
Plums
I got one through an ebay contact. Red dot brand, which supposed to be reasonable, 2 speed fan, 250mmW x 190mmD x 110mmH, $149 + postage which was about $13 Qld to Vic. Part No. HA2701.
I think these are used in excavators but he converts before use to A/C at least I thinks that's the story for the ebay stuff, mine came in a red dot box. I'll send you an email, hopefully, with three pics of the heater.
You need to fabricate a face to direct the hot air but that's no big deal - did mine in f/glass.
slowy
05-08-2007, 05:53 AM
VIC
I hear the Vintage Air 50615-VUH is a great compact unit. Scroll down on this link...
http://www.vintageair.com/downloads.asp
05-08-2007, 06:59 AM
Originally Posted by sambo
Yep, I have this unit and am super impressed.
05-08-2007, 09:41 PM
Well done!
Regards.
Mando
05-08-2007, 10:17 PM
WA
Thanks to everyone for the replies re: heater.
Thanks for the e-mail Steve, do you have any pics of your fibreglass ducts??
05-09-2007, 06:43 AM
Vic
Bobby
I've only fiberglassed up the rectangular box to cover the end. I did this initially on a box of the same dimensions as the heater end but I ended up undersized.
I ground the inside of the box so that it would fit the heater, but it got thin walled and fragile so I covered the heater end in a number of layers of cling wrap refitted the box and wrapped more glass around the outside to gain more thickness and strength.
Some sanding and reglassing and I now have a very durable, perhaps not so pretty rectangular box.
I plan to create the f/glass connection tubes by wrapping the right sized tube with glass to achieve the needed OD for the heater ducting. Will cut, glue and shut this f/glass tubing to achieve the direction I need of the outlets later.
Heater is in soley for the sparky to wire up. I will make it work later, probably after rego. as the engineer doesn't need it either. I have created the holes in the dash so if I get free time this is one of those jobs I can progress later.
If you want the email contact of this heater bloke let me know.
slowy
