Old 06-11-2007, 07:49 PM
Thomas Gayer's Avatar
Cobra Make, Engine: B&B 66 427W Roadster
Default Best Ford Small Block Heads
Has anyone heard of Chi heads?
They are supposedly Aussie and the best flowing out of the box.
thanks,
Tommy
SSSSSSSSSSSSS
Old 06-11-2007, 07:59 PM
LoBelly's Avatar
Hello Thomas
haven't heard a bad report about them
you can check out their web site at
http://www.chiheads.com/
I think the site has everything you'll need to know
LoBelly
Old 06-11-2007, 08:29 PM
Thomas
you can read more about them here http://www.jonkaaseracingengines.com/
Old 06-11-2007, 08:35 PM
I have Trick Flow "O" ring twisted wedge AL heads and was surprised when someone told me there was better out there, out of the box.
Quite a bit of info on the site.
Tommy
SSSSSSSSSSSSS
Old 06-12-2007, 03:52 AM
427 S/O's Avatar
A few years back I use to drop by Kasse's shop to shoot the bull from time to time, not anymore. I remember he was just starting to build those 'monster' motors. Hell of a nice guy...
Perry
Old 06-12-2007, 04:10 AM
My ideal engine....351w and CHI 3V heads.
Got a couple of mates with em on old falcon GT's ...... very impressive.
Old 06-12-2007, 05:40 AM
BMK's Avatar
BMK BMK is offline
Thomas Gayer
Tommy,
Give John a call on 011 613 9583 5727 in Melbourne Australia..asbout 15 hours time diffference.
They are located in the east Melbourne suburbs and are well known in the Ford GT car club circles.
McDonald Racing have also used their 4v cast Clev. heads. Have not heard any negatives.
Bernie Knight
Old 06-12-2007, 05:44 AM
speed220mph's Avatar
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Yates . . . enough said.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
Old 06-12-2007, 06:28 AM
rdorman's Avatar
Renegade Nuns on Wheels
CHI heads rock.....
OhioCobraClub.com
LondonCobraShow.com
Old 06-12-2007, 10:48 AM
IKE's Avatar
IKE IKE is offline
Cobra Make, Engine: Everett Morrison, vette suspension, 351C w richmond 5 spd
I have chi heads on my cleveland, I replaced the 4V boss heads and could not have asked for a better engine upgrade. Bought mine from T-Meyer in Minn.
Old 06-13-2007, 02:08 AM
Jac Mac's Avatar
Smile
Yates if your prepared to build the rest of the motor to suit- pistons-pushrods-header bolt pattern.
Chi or 3v if you have a 351c, Boss 302 & dont want get into the piston dept, and want all the original bits to fit ( although the intake manifold to match these heads is a virtual must ). I've built a couple of race motors using these and am real happy with the results.
Jac Mac
Old 06-13-2007, 03:27 AM
Bernie,
All the Hurricane Katrina water finally drained out of my clock, so 15 hours would be 8:30 tonight if it is 5:30 am here on Wednesday. I was thinking of the Chi Chi s for my GT40 neutral balanced motor instead of those 69 D0OE s I have. You should see my 6foot 110 kg frame get into that little thing. <g> Would it be too much to ask what size jets you are running primary and secondry in your Holley dp? Thanks awfully much.
Tommy
SSSSSSSSSSSSS
Old 06-13-2007, 05:04 AM
BMK's Avatar
BMK BMK is offline
Thomas Gayer
Tommy,
Best to 'Google' - time in Melbourne Australia there and you will get the dead accurate time then..
After driving the GT40 in the States - we did the Phoenix Az. along Route 66 to London Ohio for the London Cobra show - I know what folding 6' and 110 is all about.
Although, I was very comfortable driving the GT40 in all conditions. It did take a while to get reversing sorted..
Hit my elbow once on the park brake when changing gear in anger - Hershal was asleep at the time.. Had the GT40 flying along the freeway..
..Holley
Re the Holley I have reverted back to the stock set up after trying various jets in various applications..
Currently I have 72f and 78r I think these are the stock set up.... I have checked the engine at 12:1 air fuel ratio and it's running quite well with the stock set up.
# I set the floats so that the fuel is just trickling out slowly. Played a lot with the mixture screws to get it smooth.
# Tried 68f and 72r and with the cam found that it was all over the place with the air fuel through the rev range. I played with squirters, float settings, jets, springs and accerator pump and eventually settled on the stock set up again as it was an out of box package. I felt the carby was ideal for the motor and my requirements.
I even tried cam settings in early days with advance of 2 degree - I think.... - it was a set up I tried for lower to mid range torque.
I have had a 650dp on it for a while after borrowing it off a build engine with 71f and 76r and even took that to 70f and 76r thinking it made a great difference with cruising.
So after all that back to the stock jetting and all appears OK.
.. are you confused now.
Interestingly, the NASCAR motors with small blocks run 500 - 600HP using a Holley 390 2 barrel and they even have restricting plates..... I often wondered if I had been over carburating the engine with the 650 and the 750. Then again, it is what you do with the right foot and what you expect.. so in went the NOS 150HP jet set up..
Bernie
Bernie Knight
Old 06-13-2007, 05:24 AM
Aussie Mike's Avatar
Did you pull the Quadrajet setup and switch back to the Holley Bernie?
Mike Murphy
Melbourne Australia
Old 06-13-2007, 05:48 AM
BMK's Avatar
BMK BMK is offline
Aussie Mike
Had the old manifold on and the Holley with the old cleaner.
Now all legal again...
This was how it was previously set up. So gave it a try again and it was back to the new economy set up....and legal good boy. No NOS gas connections....
Bernie Knight
Old 06-13-2007, 05:53 AM
BMK's Avatar
BMK BMK is offline
Aussie Mike
Mike,
Have you put stripes on the body prior to rego.
Will you paint it over the next week or so prior to rego..
Bernie Knight
Old 06-13-2007, 05:21 PM
Hi Bernie It'll just stay mat black for a while. It probably wont get paint till next year.
Sorry for the Hi Jack.
Mike Murphy
Melbourne Australia
Old 06-16-2007, 04:12 PM
BMK's Avatar
BMK BMK is offline
Good to hi jack once a 'Thread"' slows, it gets it back to the top again..
Bernie Knight
