Old 11-22-2007, 02:25 AM
a rough guide is for around 2500 dollars ill supply
complete engine loom wired to suit with relays fuses accell pedal wiring etc
ecu with security removed
accellerator pedal
and mass air flow meter
will look into mafless and performance tunes
these will cost extra not sur eon price yet
my website
www.sideshowsperformancewiring.com.au
Old 11-22-2007, 03:58 AM
Tenrocca's Avatar
Sidey - can you get the engine check and oil warning light working with the E38\L76? Looks like you need some sort of CANBUS interface, (No not canibus Mike ) Is that right? Do you supply your looms with a OBD2 connection as well?
Old 11-22-2007, 04:11 AM
yes u have ti wire in the check engine light
l76 has these in the ecu from factory
the ls1 needs a wire fitted and the tune modified for mil light to work
all my looms havve obd2 connectors cause i test them before i send them out if i have an ecu lying around
if the l76 is auto u have to wire up the can bus wiring to auto and engine ecu
i now have a late model diagnostic scanner and just bought the can bus adapter so i can do alot of stuff with very late model holdnes and others
im goin to get into diagnosing late model cars aswell
my website
Old 11-22-2007, 04:31 AM
sambo's Avatar
Thanks Sideshow. As mentioned I don't have the engine yet but I do have the pedal so I'll be in touch when I get closer to needing the ecu, loom etc. How much time do you generally need to put all that together?
Old 11-22-2007, 05:48 AM
i can get loom finished in 2 to 3 weeks
my website
Old 11-22-2007, 01:48 PM
Tenrocca's Avatar
Are you saying I should have a direct line out from the ECU to the MIL light ? - as I cant identify which ECU pin that is from the schematic I have. Cant ID the serial data line for the OBD2 connector either, although the abbreviations on the schematic are a little ordinary.
Old 11-22-2007, 11:35 PM
its on the missing plug that is not on the main enigne harness
there is a crappy diagram goin round for the l76 hehehehehe
my website
Old 11-23-2007, 02:37 AM
Tenrocca's Avatar
haha - yes i think thats the one I have. It seems to have most things but it is bloody hard to interpret. I have a Z06 schematic (that uses the E38) and its brilliant...eg. "MIL light out"....Think Im missing that on mine. So the MIL pin number is???? haha
Old 11-23-2007, 03:32 AM
G'Day, I'm not local (newcastle nsw) but I must say please DON'T use tek screws. they are meant for a once only fitment like in shed walls. Believe me you will unbolt stuff and rebolt it lots of times and tek screws don't like that.
Enjoy your build and experience the legal crap. (no one understands, until they live it)
Smithy
Old 11-23-2007, 05:13 AM
sambo's Avatar
Thanks for the tip Rob. So what would you use to secure the P-clips for the brake lines? Mine will be going into steel chassis rails, I'm guessing 2-3mm thick.
Old 11-23-2007, 03:19 PM
stephen low's Avatar
Sambo
If there is enough meat in the chassis you could drill and tap and attach directly. I've done this for fittings in the engine bay.
Another good trick I was put onto are aircraft anchor nuts. Essentially a captive nut held in a frame, with the frame riveted into place to hold the nut where you want it.
Come in all different thread sizes and even plain, nyloc or metal lock threading. means you can unbolt bits very quickly once all assembled.
Just another thought!
slowy
Old 11-23-2007, 04:51 PM
Tenrocca's Avatar
5\6mm nutserts and button head stainless (loctited)
  #33 (permalink)
Old 11-24-2007, 10:44 PM
RODA's Avatar
Cobra Make, Engine: Classic Revival LS1 6spd
Sambo
The other place to go is Lockbar Steel, they are also in Moorabbin.
They have a great range of both steel and aluminium and will cut to size.
They are also open Saturday mornings.
Rod
  #34 (permalink)
Old 11-24-2007, 11:54 PM
Outwest34au's Avatar
Originally Posted by stephen low
Paul
as the old foster signs say, I allus has one at 11!!
Or is that the D.A. signs?
Do they still make Diners Ale?
Ya get that on big jobs.
  #35 (permalink)
Old 11-25-2007, 05:08 PM
Tenrocca's Avatar
Got it . Mil = X1\68.
  #36 (permalink)
Old 11-25-2007, 07:31 PM
Diners Ale must be a Qld. CUB offshoot at least Fosters is exported!!
Sadly neither saw nor heard from you Sambo, another meeting blow out!! I might have to come to you once the car is registered.
slowy
  #37 (permalink)
Old 11-25-2007, 08:09 PM
sambo's Avatar
Ah sorry mate. I meant to call you to say I couldn't make it - a product of running around to buy stuff on Saturday til about 1pm and I knew you were busy after 12 noon. Yesterday I had a partner to pay attention to after a full day with the car Saturday. Stephen I will make it a priority to drop in one weekend soon. It's a busy time of year for all I imagine. I hope to make the VCCC meeting next week also.
Paul
  #38 (permalink)
Old 11-27-2007, 03:28 AM
Asp302's Avatar
Cobra Make, Engine: Homebush fibreglass body and chassis, running stage2 302 cleveland on LPG.
BUNNINGS will supply most of it and threaded rod
  #39 (permalink)
Old 11-28-2007, 07:11 PM
sambo's Avatar
I finally tracked down a nutsert tool after a tip-off from Total Tools... they sent me to Economy Bolt Company in Keysborough who are open Saturdays. Cheapest price on the tool ($230 in the m4-8 range with lots of rivnuts), made in USA and does a marvellous job. They also stock tons of fasterners and are very helpful. I can't believe nutsert tools are so hard to come by in Australia - we have a thriving hotrod industry after all.
