Old 11-26-2007, 03:06 PM
Merv and Sharon's Avatar
Default Fitting gauze panels
Was wondering about the best/neatest way to fit the small gauze panels on the front vents of a Harrison (oil cooler vent and brake vents)? Could screw to f/glass but that is thin. Could use Sikaflex but that is fixed. Any suggestions?
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 11-26-2007, 03:36 PM
sambo's Avatar
Merv, after getting a nutsert tool on the weekend I can see myself using it all over the car, including fibreglass panels. Maybe see if you can borrow one and try the m3 or m5 inserts with the gauze.
Old 11-26-2007, 03:46 PM
Default nutsert
I am beginning to think that this nutsert tool is the answer to everything including dentistry! Will have to see what they can do!
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 11-26-2007, 10:40 PM
Cobra Make, Engine: DRB,Ford Tickford 302 220kw with BTR 4 speed auto, 3.9:1 LSD
Velcro! would probably work well for the brake vents.
Cameron
Old 11-26-2007, 11:10 PM
BJ's Snake's Avatar
Merv,
I used Sikaflex for mine and have not had any problems yet.
brett
289 FIA Cobras RULE!
Old 11-28-2007, 01:23 AM
Bryan Wilson's Avatar
Default Holding grills on
Mine are held in place with stainless self tappers into the fiberglass.
Bryan
VK3KDN
Old 11-28-2007, 04:20 AM
stephen low's Avatar
Merv
Better still why bother?
Are you attending to keep half house bricks from entering some ducting??
slowy
Old 11-28-2007, 06:10 AM
400TT's Avatar
Good point Stephen, I think I lot of people(me included) fit them mostly for looks though.
You can just use small bolts through that internal inner guard wall to affix.
Or screw through the brake duct flange, inside to outside to affix mesh. Gives a more vintage/original look. Although a bit tricky to do. My current Cobra is done this way.
www.absolutepace.com
Old 11-28-2007, 05:53 PM
PCC's Avatar
PCC PCC is offline
Sikaflex is the way to go.........
Brake Vents - mould the mesh around the opening and glue on
Oil Cooler Vent - left open
Bonnet Vent - again mould to the opening and glue on (I have a very wide opening and was finding that at speed it was stressing where the vent is moulded to the bonnet. The mesh prevented further stressing).
PCC (Peter Craig)
Keep the sun shining
Old 11-29-2007, 02:22 AM
Thanks all! I am thinking that they are cosmetic only and if fitted then either bolted to the adjacent chassis frame or using Sikaflex. I was only going to use the mesh over the cooling vents not over the oil cooler vent or the radiator opening. May also use some of the chromed steel mesh if I can find some, instead of the ally.
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 11-29-2007, 04:52 AM
BMK's Avatar
BMK BMK is offline
Merv and
Sharon
Did you get the vents mesh from Finishline?. I found them there and they were reasonably price.
www.snakebite.com.au has them also.
Bernie Knight
Old 11-29-2007, 05:16 AM
400TT's Avatar
Merv
I prefer the look of the alloy expanded mesh. I've only seen the stainless mesh in that woven wire type design.
Old 11-29-2007, 05:33 AM
Yes I have the expanded alloy mesh now and I am not sure about the woven wire SS mesh - it does look 'period' in some ways. I could not imagine where one could buy or even see it!
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 11-30-2007, 12:19 AM
The stainless mesh can be obtained from Europa Spares in England. They sell it in kit form for Cobra's Grill, brake and oil cooler openings.
www.europaspares.com
Cameron
Old 11-30-2007, 01:50 AM
Thanks Cameron. I also found it at Metal Mesh in Underwood in Brisbane. Seems that have lots of offcuts!
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
