Old 04-29-2008, 11:46 PM
sambo's Avatar
Default Electrical bits - Shrinkshop
After seeing the neat wiring job on the Daytona cars at the factory tour on the weekend, I've been hunting around for a good source for heat shrink, terminals, wire, etc.
This site looks to be the best value for money and no doubt the Canadian exchange rate will help.
http://www.shrinkshop.com/index.php
Does anyone know where to get wire disconnects from? Not the crude male/female snap plugs, but two piece disconnects similar to the molex plugs inside your home PC. eg, the ones you plug into your hard drive.
Paul
Old 04-30-2008, 12:13 AM
Krait's Avatar
You can try Farnell http://www.farnell.com.au or RS Components http://australia.rs-online.com/web/
I think I got most of mine from electrical wholesalers such as Lawrence & Hanson. I used Utilux terminals throughout to ensure compatibility. The expensive bits back then (15+ years ago) were the tools.
Edit:
A quick look at the Utilux webite shows they don't list moulded connectors any more. They have been bought by Tyco, who also own similiar companies, so maybe they've rationalised production.
I see another company Semico http://www.semico.com.au in Sydney appears to be stocking similiar gear. By luck I'll be in Sydney for the next few days and will be staying a stones throw from Semico. I'll drop in and check them out.
Geoff
Old 04-30-2008, 05:51 AM
i just have to ring a guy and he usually drops round within 2 days
and i just get stuff he keeps in his van
its like a boy in a toyshop
but not sure if he will drive to melb heheeheh
i just use the plain white plugs with brass terminals
they do ok job u can get waterproof stuff and german plugs but how much o u want to spend
i have not had probs with the basic white plugs just sometimes when custoemrs try to wire things themselves and dont use correct crimpers hlf the wires can pull out
but even crimps i do with proper crimpers sometimes once in a blue moon pull out
but u should be able to buy everything u need at a decent auto aprts shop
not supercheap
even if u buy bulk stuff u wont save much
if i wire a whole car prob spend up to 300 in parts
the terminals and plugs are only bout 50 bucks
if u buy a pre made loom then u dont need much extra wiring
te proper crimpers are about 50 bucks and u ge tthem from jaycar
my website
www.sideshowsperformancewiring.com.au
Old 04-30-2008, 05:53 AM
also jaycar sell heat shrink too
bout $1.20 per 1m length for 3 mm stuff
each time i go there i buy about 100 bucks worht of heatshrink
beware when using the hard drive connecotrs on wire 4mm or bigger
plus the hard drive ones are hard to find
one i use i can find at most auto parts shops
just goto narva website u will find everhting there
write down part numbers and then goto yr shop and say order me this
my website
Old 04-30-2008, 06:50 AM
sambo's Avatar
Thanks Geoff. That Seminco link didn't work by the way.
Sideshow, I just checked my wiring kit (American Autowire Highway 15) and it uses 12 gauge wire for all power feeds. I doubt the 3mm heat shrink will hold 2 or 3 of these wires. I'll be running brake, tail and indicator wires from the fuse box down the length of the car and the idea is to heat shrink them and then fasten at regular intervals to the chassis or body. What do you generally use to attach lengths of wire to fibreglass? Eg, inside wheel arches or the nose cone?
Old 04-30-2008, 07:05 AM
Krait's Avatar
Link is working now
Geoff
Old 04-30-2008, 11:24 AM
Cobra Make, Engine: Cobra-less
Don't know if these guys are available over the pond but check out alliedelec.com or www.newarkinone.com
I'm pretty sure Newark is world wide. Both paper catalogs are 2 inches thick.
AL
Cobras Gone But Not Forgotten
Old 04-30-2008, 02:46 PM
for long bits i use just the corrigated conguit think thats ho wu spell it
heatshrink at jay car comes in 3mm 5m 6m 10mm 15mm and maybe 20mm
my website
Old 04-30-2008, 03:46 PM
Krait's Avatar
Using heatshrink over a long cable run creates a fairly rigid section. Makes it difficult to mould the harness around obstacles and it prevents the cables assuming their own bending radius resulting in a contorted loom.
Heatshrink is only really designed to insulate connections or where the cable insulation has been removed.
As Sideshow says, using split corrugated conduit may be a better solution and way easier to add a cable to later if necessary.
As for fixing, in non visible areas it may be easier to hot glue, or similar, the loom assembly directly to the fibreglass body rather than trying to afix clamps. There are self adhesive plates which have a cable tie threaded through them to hold the loom, they are usually fixed using double sided tape but could be glued in place instead for longevity.
Geoff
Old 04-30-2008, 04:44 PM
sambo's Avatar
Geoff, the "heat shrink" I saw on the weekend wasn't rigid, it was almost like they didn't apply the heat. More of a loose, flexible sleeve to protect the wires from the elements. I might give them a ring and find out what they used.
Old 04-30-2008, 05:00 PM
boxhead's Avatar
Try your local Laurance and Hansen agent for plastic tubing and for heat shrink, they can supply it in a multitude of colors.
I bought the white plastic terminals from local motorbike shop.
Cruising in 5th
Old 04-30-2008, 06:04 PM
sambo's Avatar
Boxhead, they don't seem to have a store in Melbourne. I can only find the Sydney details and no website.
Old 04-30-2008, 06:34 PM
sambo,
not sure if this is what you want, but check it out anyway they have some handy stuff.
http://cableorganizer.com/automotive/
Old 04-30-2008, 07:30 PM
boxhead's Avatar
Sambo, it looks like they are only just building a website.
http://www.lawrenceandhanson.com.au/...=NONE&SRV=Page
Here are the Melbourne stores.
http://www.hagemeyeraustralia.com/wp...&postcode=3000
Cruising in 5th
Old 04-30-2008, 08:08 PM
sambo's Avatar
Thanks Boxhead, I'll give them a call. Interesting history behind the company too.
Old 05-03-2008, 05:00 AM
Sambo, I think the stuff you're looking for is called "spagetti". It's just a plastic sleeving.
There's another stuff called spiral wrap. It wraps tightly around your harness bundles but allows branch wires to exit where ever you like. It looks good too. It won't keep dirt or water out. I used it under the dash etc. Got it from Jaycar. Heat shrink is mostly used to seal up crimped connectors to the wire. It provides a semi rigid support to the wire where it enters the crimp.
Try electrical distributors like davis & spence, laurence & hansen, rovert, Farnell is real good on electronic bits and rs online is good for most electrical stuff...a bit pricey though.
Smithy
Old 05-03-2008, 03:11 PM
sambo's Avatar
Thanks Rob. I visited L & H yesterday and was told they don't have anything suitable for automotive, which is strange after all the recommendations. I'll try Jaycar today and check out those other names. Thanks again.
Old 05-04-2008, 04:02 PM
sambo's Avatar
Edit: East Coast Auto Spares is the go! Found conduit for under $1.50/m, plus the whole range of heat shrink and 'spaghetti' tubing. Can anyone vouch for Optima batteries? The 750 CCA "blue top" was $280 and seems to be better value than the equivalent Odyssey, once landed here.
Old 05-04-2008, 05:38 PM
Cobra Make, Engine: Classic Revival Kobra,LS7 427
Try Sochienstron dryfit 500As they are small and can be put is on any angle. They are rated at 15amp hours.
Old 05-04-2008, 06:11 PM
G'Day again..I've got a red 720 CCA optima it's about three years old and it seems it never loses a charge..It's been sitting on the bench for that long and each time I go to charge it it doesn't need it. They were designed for US hotrodders who hibernate their cars over the snowy winters.
I read some where that the oddesy batteries have a tendencey to drop the plates off the posts. This happened to a mate of mine. He now has an optima.
Smithy.
