06-07-2008, 08:02 PM
nsw
Cobra Make, Engine: Homebush fibreglass
Factory 5 Sidepipes
For anyone about to purchase sidepipes, here are mine just arrived form Factory 5.
The welds will need fettling and then I will get them HPC ceramic coated silver.
Cost was $US 389 + $US 179 freight to my door. God Bless The US of A! Took about 2 weeks.
I have been quoted $AU 150 per pipe for coating.
Next job to work out what all the bits are for!
06-08-2008, 06:25 AM
NSW
Those funny looking "elbow" brackets look like specific mounting bars that go from the muffler tab to the chassis. Therefore it must be a solid mount. I thought there might be some sort of "flex" in the side pipe mounts. I intend to incorporate a rubber mount in mine.
Smithy
06-08-2008, 06:42 AM
Hi Rob, looks like the rubber mounts are on the LH side of the "elbow brackets", those oval shaped things.
Regards.
Mando
06-08-2008, 07:37 AM
ma
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
on the ffr cars there is a 2x2 square steel that goes across the frame from left to right, the steel bracket gets mounted to the side pipe tab, the middle hole uses the larger rubber hanger, they use a allen head bolt a washer go through the rubber hanger another washer then a elastic locking nut the lag bolt goes to the 2x2 steel on the inner hole there is a smaller rubber mount with a stud mount that to the hanger now on the other side of the inner rubber mount it has female threads drill a hole through the 2x2 and use another allen bolt to mount the inner mount. hope that helps.
if you go to the ffr forums and look around you will find some pictures.
06-08-2008, 08:50 AM
NSW
Picture tells a thousand words:
great value on those pipes. Couldnt make them for that.
06-08-2008, 04:33 PM
NSW
Matey,
Nice pair of sand shoes too!!!!!!!!
Baz
06-08-2008, 08:59 PM
Zzz
Yes the US dollar is great - nice and low at the moment.
Should see my hand luggage..
Bernie Knight
06-08-2008, 09:01 PM
NSW
Originally Posted by Baz
Matey,
Baz
Not mine - just dragged it off the FF forum.
07-03-2008, 05:25 AM
nsw
OK, so here they are HPC coated, very pleased with the result too.
I have made 2 experimental exhaust valves which divert exhaust from the underbody pipes to the sidepipes and can be adjusted to tune the sound. I had a spigot and blanking plate put on when the underbody pipes were fabricated.
They work well so far but dont know if the high temperatures will cause them to sieze in time. At present they are adjusted by hand but might put a cable or motor drive in if they prove to be durable.
07-03-2008, 06:52 AM
VIC
So about $1000 AUD including ceramic coating - great value!
07-03-2008, 07:10 AM
AUS
These pipes are a good option, but I would be checking the length to see if they will look the way you want them to on your Cobra before ordering. Unfortunately the body measurements of Cobra kits in this area varies more than you would expect.
Just thought I would post this information for anyone thinking about ordering them.
07-04-2008, 08:28 AM
NSW
WHAT is that wally setup ??? I can't see what it's supposed to do? Is it to keep out bugs ?
07-04-2008, 09:36 AM
VIC
Looks good in theory but I don't reckon the butterfly is big enough. I reckon it'll just sound like a chuffy exhaust leak when its open.
Mike Murphy
Melbourne Australia
07-04-2008, 05:30 PM
Craig your right, a guy I know bought a set of sidepipes from the states and ended up adding 2" to their length. Lucky for him the pipes were ordered in an unpainted steel finish.
Mando
07-05-2008, 08:37 AM
VIC
Harsh
martrogers did say it was experimental
07-05-2008, 04:53 PM
nsw
Nope, it works fine, the hole can be made larger though if needed, the sound is definitely improved but my aim was not to be too loud. This also means the pipes do not get too hot to cause leg burns.
As regards the pipe lengths, they are 1250mm o/a.
My car is stretched 100mm so they look a bit short but I still like the look.
07-05-2008, 05:05 PM
nsw
....thanks for your feedback Rob.
I wonder how many "lurkers" there are on the forum who wont contribute in case they get replies like yours....
07-05-2008, 05:43 PM
NSW
Cobra Make, Engine: Homebush. Lexus quad cam V8, R154 Supra box. Oh what a feeling.
Great to see you finally got your rego Martin. You car is looking good.
Brett
 !!Its good to be stroked but i'd rather be blown!!
Proud member of the Bclub Central Coast chapter
