Old 06-11-2008, 12:04 AM
boxhead's Avatar
Default Hogster or Alffie
Hey there guys,
I have been trying to contact Jack in regards to the engineering on my car, I have been ringing his landline for about 3 - 4 weeks now but only manage to get his answering machine.
Do either of you have a mobile contact or any way of getting in contact with him.
I am trying to get the engineering side of things done for approval so I can take my car to the Nationals and not have to go in race class.
Cruising in 5th
Old 06-11-2008, 03:38 AM
Cobra Make, Engine: Classic Revival Kobra,LS7 427
Hello Boxhead
I always go into his office. He is very busy as he has taken 2 weeks to do my body inspection. Here is hes email jack.vries@bigpond.com see if you have more luck with email. Good luck with the nats. When is the dates?
Old 06-11-2008, 05:55 PM
boxhead's Avatar
Thanks for the email address.
It is on the 3rd, 4th and 5th October, in NSW.
Cruising in 5th
Old 06-12-2008, 03:40 AM
Cobra Make, Engine: King Cobra, QLD - 347 windsor
Default Me either
Sorry boxhead,
I dont have a mobile number either.
I just go into the office like Alfie.
Hogster
Old 06-12-2008, 05:09 PM
boxhead's Avatar
I have emailed him and have a reply (at least now I know he is still alive).
Have either of you asked him for an estimate of costs for engineering?
I did and I think it has upset him.
Cruising in 5th
Old 06-13-2008, 05:18 PM
No, I haven't asked but we have discussed the process.
He told me to print off the VSB checklists and go through and fill out with as much detail as possible about the specifics of the vehicle. He indicated that this would make his job easier/faster and would reflect in the cost. That was encouraging when I am nearing the end of my spending budget.
Alfie has had a chassis inspection so should be able to tell you what that costs. I'll be interested to see the answer also.
Old 06-15-2008, 12:50 AM
boxhead's Avatar
My kit came with the chassis testing data.
Can I ask what the VSB checklist is?
Cruising in 5th
Old 06-15-2008, 05:15 AM
Default Vsb 14
Gidday boxhead,
VSB 14 is the "vehicle standards bulletin" that relates to the National code of practice for light vehicle construction. http://www.infrastructure.gov.au/roa.../vsb_ncop.aspx
In the subheaded sections there are a number of checklists that builders, engineers or inspectors can make reference to when checking compliance for specific areas of construction, or components.
So for example you go to the section on fuels systems and printout the checklist that relates to your type of fuel system, then check the boxes as you go through the issues identified. If you can tick off all the boxes, and explain the modifications you have made on the way, it makes the engineers job much easier.
Thats the general idea anyway. It gives you a heads up on what you need for compliance because the rules are also explained in the same documents.
Regards
Hogster
Old 06-15-2008, 06:17 AM
Cobra Make, Engine: Classic Glass 302 Windsor
Hogster has the mass flow turned up yet?
Old 06-15-2008, 05:15 PM
boxhead's Avatar
Thanks Hogster
Cruising in 5th
