Old 06-19-2008, 10:03 PM
Aussie Mike's Avatar
Wow Mike, your computer skills are much better than mine, no matter how much I search, I cant find the same page as you, Do you have a link?
Does your PC look like mine?
Here is a pic to compare.
I wish my PC in the office worked like that right now.
Thank God it's Friday.
Mike Murphy
Melbourne Australia
Old 06-19-2008, 11:10 PM
stephen low's Avatar
Or it could be that Mr Mike's pudgy large fingers hit the U beside the I on the computer keyboard either before or after self service on his new styled computer!
slowy
Old 06-20-2008, 06:04 AM
Cobra Make, Engine: King Cobra, QLD - 347 windsor
Default Por15
I've painted a lot of suspension component and other bits and pieces with por 15.
As stated by some of the others, the finish is excellent and tough. Looks like a good spray finish and tough enough to hit with a hammer.
Just follow the instructions properly.......find the cheapest brushes you can and chuck them after use.
Regards
Hogster
Old 06-20-2008, 08:34 AM
Send a message via MSN to pezza
Regards
Hogster
I have done the same. Very easy to apply excellent finish and no brush marks. From memory it is impossible to remove from your skin so use rubber gloves. The best way to do it is to buy one of their starter kits which has everything you need and if you don't like it it hasn't cost you a fortune
Perry
Old 06-20-2008, 04:42 PM
Guys
I'm thinking about revisiting my whole chassis after sandblasting with brushed on Por15 to keep it simple for myself. I no spray painter but happy to give this option a go too, anyone sprayed this stuff on too?
I'd used it on level and vertical surfaces but am worried about runs if I am rotating the chassis on a spit to get to all the metal. What's the risk of getting runs, anyone know?
I'm thinking of two coats where there is exposure to the elements and in the engine bay but one coat where hidden and protected by fibreblass of other materials later on.
Would anyone have any inkling of the amount of paint I'd need for a chassis?
slowy
Old 06-20-2008, 04:58 PM
ItBites's Avatar
The problem you had with the spray can paint is not uncommon these days, even for regular-old rustoleum. I had the same thing happen when painting an oil pan. Had to scrape, sand, and start all over...
If you look at the directions, it will probably tell you to add second coats some minutes after the first coat. It will also likely tell you that if it has dried, then you need to wait maybe two weeks before repainting. That is what I found after reading the directions during my debacle.
E. Wood
ItBites
Old 06-20-2008, 06:16 PM
Baz's Avatar
Baz Baz is offline
Originally Posted by stephen low View Post
Guys
Stephen,
I've used Por15 on all my suspension parts and diff. If your going to paint your entire chassis with it, be prepared to take out another home loan. I only purchased a small tin, (I think it's about 500 mil) and that cost me $72.
On the positive side though, after painting all my suspension parts and diff, I still have about 1/2 a tin left.
Baz.
Old 06-20-2008, 10:09 PM
Originally Posted by Baz View Post
Stephen,
Baz.
I used 2 of their starter kits to do all my suspension parts and diff. Each kit has 100ml of paint so a small amount goes a long way.
Perry
Old 06-21-2008, 05:22 AM
I used POR15 on the chassis. Used only one 500ml can. It spreads very easily and no brush marks. Make sure you use gloves.
