Old 09-28-2008, 06:28 PM
REPTYL's Avatar
Default GPS Lap timer
I've been thinking about getting a lap timer for a while now.
I have watched as GPS technology snuck in the door a few years back.
I'm just wondering whether any problems or bugs (if any) have been worked out in the time since it arrival on to the market.
Is this technology is now a good value alternative to the old inferred beacon technology?
Is there anyone in Cobra land utilising the model listed in this link?
starlane Athon_GPSR_chrono_GPS
Old 09-29-2008, 01:46 AM
Krait's Avatar
I reckon if you only wanted a general indication of laptime then a gps based system would be ok.
The problem with gps is the accuracy can vary depending on a number of variables such as the ephemeris data (precise orbital data) from each of the satellites it detects, whether the gps has clear line of sight of sufficient satellites and whether the signal is bouncing of off objects before it gets to the gps receiver (anecdotal reports is that even a bald head can affect the signal).
Google 'gps accuracy' and you'll see what I mean
Using a ground station (DGPS) to transmit a fixed location greatly enhances accuracy but the equipment to receive is expensive and accuracy is reported to be about 3 metres. The US has a system called WAAS but it is unavailable in Australia.
I was involved in a community GPS mapping project in Malaysia. We would be happy if we had 6 metre (radius) accuracy when tracking roads and kept vehicle speeds to <60kph otherwise the track would overshoot on bends.
Hope this helps.
Geoff
Old 09-29-2008, 07:49 AM
Hi Guys
Log onto' Racer Industries' website.
They have a nice little performance logger.
Dimi
Old 09-30-2008, 04:14 AM
acecob's Avatar
Default How new is your phone
Here's a tip , most new phones now have gps and nav stuff on them,
you can download a little prog called sports tracker it utillises gps and maps ur circuit gives you speed and basically all the info you need, its pretty neat
Old 09-30-2008, 07:23 AM
LoBelly's Avatar
Looks like a groovy bit of kit Jason
Do you know how much and where from?
ta
LB
Old 09-30-2008, 07:37 AM
kayakjack's Avatar
Default Traqmate
Try this...
www.traqmate.com
I've used it. It will give you lots more data than simple lap times. Very accurate. Highly recommended!!
Jack
Old 09-30-2008, 07:40 AM
kayakjack's Avatar
Default Traqmate
I googled them. Here's the link to the Australian distributor...
http://www.traqmate.com.au/
Jack
