November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 10-29-2008, 07:27 AM
Andrew429's Avatar
Cobra Make, Engine: G-Force MkII, Ford 429, Tremec TKO, Jag Suspension, Sequential LPG Injection, On The Road.
Default Tremec TKO speedo plug
Hi All,
I'm chasing some specs / photos for the plug that fills the mechanical speedo pick-up hole in a Tremec TKO / T-5 / T-45.
I've installed the gearbox and then read the instructions
I will spin one up on the lathe if I can find out a little more info.
Andrew
Old 10-29-2008, 07:54 AM
Give Mal Wood a call 07 4661 3548
Old 10-29-2008, 06:53 PM
Cobra Make, Engine: King Cobra, QLD - 347 windsor
Mal Wood has the senders with the Chev pigtail plugs on the end...........chased him looking for the ford pigtail, but had to find one elsewhere.
Regards
Hogster
Old 10-29-2008, 09:48 PM
car4jim's Avatar
Cobra Make, Engine: Kirkham, 427 side oiler
I have a drawing of a plug engineered to fit a TKO600 if you have access to a metal lathe, dial calipers and some alum bar, I will need to scan the drawing, so let me know if you need this info
Old 10-30-2008, 12:29 AM
Andrew429's Avatar
Post
Hi car4jim,
That is exactly the info i'm after.
Thanks
Andrew
