Old 12-20-2008, 10:50 PM
Baz's Avatar
Baz Baz is offline
Default Helpful Hint For Fitting Roll Bar Stays.
A helpful hint for anyone installing Roll Bar Stays. After the hoops have been positioned, place a torch inside a section of rubber hose and push that hose up onto the point where the Rear Stay attaches to the Roll Bar Hoop. The light from the torch indicates the exact point where the holes are to be cut through the body for the Rear Stays to be attached to the chassis. You can see the set-up better in the photo above.
Baz
Old 12-20-2008, 11:15 PM
mickmate's Avatar
What a super idea! Only problem might be that a torch needs to be translated to a flashlight for the seppos or they might think it's a donut poo, shirt lifting, pillow biter??
mickmate
http://www.actoncustom.com/
Old 12-20-2008, 11:55 PM
Dominik's Avatar
Default Laser
I use a laser pointer for similar results. (Also for wheel alignment)
Everybody should have one, and the latest cross-hair lasers.
Dom
