questions
- » Blogs
- » Image Gallery
million posts!
November 2025
| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
12-23-2008, 04:09 PM
Vic
Merry Christmas
Have a Merry Christmas Boys and Girls
And remember if you are going to drive over this festive period......
Take your car!
Oh and by the way, who has run a remote bleed system from their Jag brakes?
Anyone with photos of such a set up I can copy whilst I can still easily get to these bits.
Steve
slowy
Advertising
12-23-2008, 04:22 PM
WV
Cobra Make, Engine: Shell Valley Roadster,428FE, 2X4's; 1966 GT 350 Clone; 1968 Shelby GT-350
Merry Christmas to you and all our brothers and sisters "down-under."
steve
12-23-2008, 04:29 PM
Cobra Make, Engine: RCM, 4 wheels, two doors
Merry Christmas everyone and have a safe time on the roads over the break
12-23-2008, 04:52 PM
NY
Cobra Make, Engine: 1969 Mustang Fastback Pro-Street, constantly changing ongoing project!
Merry Christmas everyone! Enjoy the time spent with Family & Friends. Be safe!
Regards,
Mick
(Of The Troops & For The Troops)
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body; but rather a skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, WHAT A RIDE!"
NT
Yes, Merry Christmas to one and all, take care if driving.
Cruising in 5th
12-23-2008, 05:59 PM
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
Merry Xmas May santa bring plenty of chrome goodies....
Cheers Mark
12-23-2008, 06:45 PM
VIC
Merry xmas everyone!
Santa came early and I have a new house, double garage and T56 to go with the 6.0L. When the Cobra comes home from Kenmer I'll post some photos.
12-24-2008, 02:34 PM
Cobra Make, Engine: 1st Harrison with Gen 3 , 6 speed ,Godzilla diff & brakes
Merry Christmas to all and a happy new year.
Dont drink to much
Paul
12-24-2008, 03:40 PM
Vic
Paul
You could at least post a pic of the new workshop.
It would be good to see where you are going to spend a lot of your time in the next year or so - DoH
Anyone got any remote brake bleed pics. for me?
Steve
slowy
12-24-2008, 03:55 PM
Zzz
Merry Christmas to all and a great New year....see you in 2009
Bernie Knight
12-24-2008, 09:40 PM
tx
Cobra Make, Engine: Lots fo different cars that change all of the time
Bmk
YOU KNOW!!!! !! Merry xmas from the big Texan.
Jay
ALL I WANT IS A NICE SWEET NYMPHOMANIAC DEAF MUTE THAT LACTATES TEQUILA
Run & Gun participant 1998-2005
12-25-2008, 03:04 AM
QLD
Merry Christmas all
12-25-2008, 07:01 PM
VIC
Slowy, the garage is full of empty boxes and stuff, plus I'm waiting for ADSL to be connected and it's not much fun trying to upload pics on the mobile. Hopefully next week.
12-28-2008, 12:50 AM
NSW
Santa's coming a bit late to me. Hopefully he will be here around Easter with a bright, brand new Cobra spewing out about 350kw.
Baz
12-28-2008, 03:14 AM
Vic
Hey Baz, Santa is only a tad late for me, around the 3rd of Jan I should hear about my new tko600 appearing, here's hoping.
Bet you can't wait though!!
Now was it you that talked about remote brake bleed points to the jag rear brakes many many moons ago?
slowy
12-29-2008, 12:44 AM
NSW
Sorry Stephen. Not me. I would be interested in that topic also. Hope you can find out who posted the information. Keep me updated.
Baz
12-29-2008, 02:07 AM
Vic
I found the reference
Rebel.....you crusty ol devil - you talked about remote bleeds in a thread but did you fit these?
Now is my chance and having had to bleed under car I think it might be worthwhile.
slowy
12-29-2008, 04:39 AM
QLD
Twas indeed me...damn, that'll teach me to read all the threads.
Tis easy job Stephen, replace bleeder nipple with a pipe fitting and run brake tube to where here ever is a easy place to get too. On outboard end of the line is a bleed nipple.
I've seen it done with flex tube (like flex brake tube) but I did it in 3/16 solid brake pipe. I just remove a rear wheel and the bleed nipple is on the underneath of the side rail above the drive shafts. Tis important to keep the bleed nipple above the caliper.
12-29-2008, 05:50 AM
Vic
Thanks Rebel
If I set this up it will be in ADR flex as that is what I've used on the input side.
This might just give me some flexibility if I have to drop a caliper off its mounting location and then I haven't opened the system.
I'm assuming the height helps expel air better.
What effect would air have if it was at the end of this remote bleed point but the caliper system was fully bled?
slowy
12-29-2008, 06:10 AM
QLD
Stephen, air has no place in brake lines. Two reasons...it compresses so leads a "squashy" feel to a pedal. Second...air is a component for corrosion.
If your bleed nipple is above the caliper then you should be able to get all out of the system.
Using this remote bleed you will be able to bleed without being a contortionist or needing to put the car on a hoist or ramps.
I actually made a power bleeding thingy from a 2ltr heavy plastic bottle and some scavenged tube and fittings, which connects to my compressor. Obviously I use very low pressure...just enough to pump the fluid thru the lines and it works a treat. I have heard of folks using a similar device and just using an inflated inner tube to supply the air pressure.
