Old 02-14-2009, 11:07 PM
Default Getting there.... Engineering complete!
As the title suggests, I finally pulled my finger out and had the car engineered this morning.
I clogged up the sidepipes to get the sound level down to 89dB... it's so quiet that missus loves it and I hate it. I made up some temporary heat shields from alluminium "see through" mesh using some spacers and large hose clamps.
I made the "wind deflectors" from perspex, and just attached them to the body using the demister screw holes. I can't wait to get the real screen back on after rego, as the wind noise and buffeting is terrible.
Just have to wait for the DPI technical section to give me the nod to take it over the pits..... that's the next hurdle!
Here are a few pictures of it in engineering and rego trim.
Old 02-14-2009, 11:14 PM
Cobra Make, Engine: Superformance (AUS 09 or SPF 2792) - LS7 427ci
Congratulations Bobby!
Terrific news...good luck with the Rego Bobby....I assume you'll be visiting the Midland centre...I just hope you encounter the same boys I did as they were genuinely interested in the Cobra as they don't get to see many!
Ok, so when can we go for a cruise together??
Regards....Paul
Old 02-14-2009, 11:15 PM
Mando's Avatar
Fantastic car, I love the fit and quality of the bodywork!
More pictures please.
Regards.
Mando
Old 02-15-2009, 03:05 AM
Aussie Mike's Avatar
Great Stuff Bobby. You would have to be happy with that!
Mike Murphy
Melbourne Australia
Old 02-15-2009, 03:56 AM
albanycobra's Avatar
Hi Plums
I think I spotted you on Reid highway/tonkin highway Sunday morning....I was driving the Red Westfield.....Looking good Mate.
Old 02-15-2009, 04:19 AM
Yep that was me, I saw you too. I was heading to the Engineers place over near the coast. With just the pathetic little wind deflectors that I had made, instead of the proper windscreen, I was almost deaf from the intense wind noise by the time I got home - a 70 odd km round trip....
Paul, as soon as she's got rego I'll come up to your place for a visit. Then soon after I'll have to "stick it in the garage" for a little while, so I can get the sidepipes coated, (and take the 89dB stuffing out of them) and do a few other minor things....
Next hurdle.... the DPI inspection
Old 02-15-2009, 09:02 AM
What did you use to stuff the side pipes with ? I'm interested.
The reverse lights and reflector brackets are a clever attachment too
Old 02-15-2009, 03:13 PM
Inside the 4 inch sidepipes I have a 3.5 inch cat and a 2.5 inch hotdog. I tacked some perforated steel to the outlet of the the hotdog to hold my stuffing in. Inside it is a length (about a foot) of 1 7/8 tube with a cap welded on the end. The whole thing is stuffed with about 20 stainless pot scourers.
Basically, the exhaust gas has to squeeze through the equivalent of a 1/2 inch pipe.... then go through the perforated steel. This is the same on both sides of course.
Even though it's badly bunged up, it still goes ok...
Old 02-15-2009, 03:49 PM
Well done Bobby,
The dash looks great.
I might need to borrow your bungers when your done with them.
Old 02-15-2009, 05:33 PM
I'm sure you can borrow my 1 7/8 "bungers" after I get through rego.
The dash surround has come up quite well. After rego I'll polish it along with the roll bar. I have been thinking lately that perhaps I'll give it the brushed look, so it matches the shifter and steering wheel....
Old 02-15-2009, 05:56 PM
LoBelly's Avatar
Your car has come up very well Plums
You see penty of black cobras but getting the overall scheme to look this good is not that common.
Also like the way you kept cockpit clean and simple - top job
LoBelly
Old 02-17-2009, 03:39 PM
Gav's Avatar
Gav Gav is offline
well done Bobby, one step closer.
I havn't even got mine out of the shed since engineering, driving without a windscreen is knackered.
I agree with how well your dash has come up, looks very neat.
Gav
Powered by Cu
Old 02-19-2009, 07:39 PM
Ross Smith's Avatar
Cobra Make, Engine: RMC 302 Windsor Supra 5 speed Jag Suspension
It's looking good Bobby,
I took mine to Midland and the guys there were good.
They may pick on your rearview mirror as it is not compliant. I used a compliant day/nite mirror and they failed me the first time becuase it was not mounted high enough on the windscreen. What's the reason for not using the proper windscreen?
Good Luck
Ross
Old 02-20-2009, 12:32 AM
Very good ! Mine was registered on gas to beat the new emission laws and I had it muffled down so much that I had to attach a vacuum cleaner onto the exhaust to get it to start. That only happened about 4 times but it was very funny. Start it, it fires, Jump out and disconnect the vacuum cleaner before it blew up. I couldn't run the engine too hard .too much backpressure
Old 02-20-2009, 01:23 AM
The mirror meets the ADR so it should be ok.... I'll be in trouble if I have to mount it any higher
I went without the screen so I don't have to worry about wipers/washers etc.
Paul also went through Midland and said it was good, so fingers crossed for me!!!
Old 02-23-2009, 09:40 PM
I got my "Approval to register a custom built vehicle" letter from DPI yesterday... getting so close now I can taste it!!!!
My appointment for the pit inspection is next Tuesday, so fingers crossed I'll be cruising the streets in two weeks time (after some things fall off/out of the car and it magically lowers itself and a windscreen appears)....
Old 02-24-2009, 05:39 AM
Ross Smith's Avatar
Go Bobby!
Paul and I will be ready for a run as soon as you are.
Old 02-24-2009, 01:51 PM
Mando's Avatar
Hi Plums, do you intend installing the screen after rego or leave it off permanently?
Regards.
Mando
Old 02-24-2009, 04:06 PM
boxhead's Avatar
All good stuff Bobby
Cruising in 5th
Old 02-24-2009, 05:05 PM
Hi Mando,
The windscreen is going on as soon as possible after rego....
It really sucks driving with just the "wind deflectors" I would equate it to stepping out onto the wing of a 747 whilst in the cruise at M.86
