questions
- » Blogs
- » Image Gallery
million posts!
November 2025
| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
03-02-2009, 10:26 PM
WA
No Rego for me...
I failed my rego inspection today
Apparently I need to make a "Grille" for the front of the car and also install the side vents (or otherwise block the holes)....
A Cobra with a "Grille".... has anyone had to do this???
Advertising
03-02-2009, 10:41 PM
Vic
Bad luck Bobby
What they are worried about someone leaning in there and burning themselves on a hot radiator? Seems the WA road authority is a stupid as the rest around the country.
Grills have seemed to have been a personal choice but perhaps no more. Just another item that falls off after rego perhaps.
So hop to it and make up some disposable items to get on the road!!
slowy
03-02-2009, 11:03 PM
QLD
Bobby, I'd have a chat with both RMC and G-Force to ascertain their knowledge of the requirement of a grill.
Maybe there has been some mis-interpretation of the rules.
Best of luck.
03-02-2009, 11:05 PM
WA
Cobra Make, Engine: Superformance (AUS 09 or SPF 2792) - LS7 427ci
Sorry to hear that Bobby!
Nevermind...book your next inspection date straight away and it will only be probably another week before you get your approaval...Meet those 2 requirements and it will be a lot harder for the inspectors to knock you back next time round!
A bloody grill??? I have never heard of anyone requiring a grill for rego either!
I'm sure you can fabricate something up for a grill and side vents pretty quickly Bobby!
Regards.....Paul
03-02-2009, 11:15 PM
VIC
Man those WA guys are strict.
I had no grille and no side vents.
My Vic Roads guy was only interested in the Vin No and Eng no and made sure I had not removed my mirrors or lights.
Good luck next time around.
Rgds
Gregg
03-03-2009, 02:42 AM
WA
Cobra Make, Engine: RMC 302 Windsor Supra 5 speed Jag Suspension
Bummer Bobby
Those guys at Midland are so inconsistent. I can understand the side vents, but a grille! that's daft, anyhow, if that's all they want just do it ASAP and get those plates.
Ross
03-03-2009, 04:00 AM
WA
It's not the end of the world.... it is mildly annoying though
I've booked it in for next week already, so I'll just get the side vents from Rob at G-force, and then make up a "grille" out of the expanded mesh I used for the sidepipe heat shields....
The guy did say that if I fixed those things there should be no problems!!!
03-03-2009, 05:43 AM
NV
Cobra Make, Engine: 427 SC
03-03-2009, 01:00 PM
Cobra Make, Engine: 1st Harrison with Gen 3 , 6 speed ,Godzilla diff & brakes
Hi Plums
make the grille for easy removal after rego
i have a box of removed items that need to go back on if i ever have to take it back to motor reg
Regards
Paul
03-03-2009, 07:29 PM
Plums, sorry to see you did get Rego, hope things go smoothly for you next week!
Regards.
Mando
03-03-2009, 08:03 PM
vic
Just make a grill and glue it in so it falls off later.
Hope all goes well next week Bobby.
Still waiting on my VIN number and then it is all go, freaking frustrating waiting on pen pushers to pull their finger out though.
Powered by Cu
03-04-2009, 07:48 AM
Qld
Cobra Make, Engine: Harrison, Cammed LS1, 6 speed
So Close
Hey Plums,
Hope all goes well on the next round! I have heard there are a few things that fall off after rego, make sure you take the 'rough' road home!
The only thing I hate about doing nothing is that I don't know when I'm finished
03-05-2009, 03:38 AM
QLD
Maybe they are not as used to Corvaces? Making up a simple woven mesh grille should not be a problem.
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
03-05-2009, 06:07 PM
Vic
Not a fan of grills much as it sounds like you aren't either too Bobby, whether just for the work or the look but have to admit that fine version Kris links too isn't too bad.
I don't have that decision so it's all academic. Send pics once done Bobby so we see your handy-work.
slowy
03-05-2009, 06:35 PM
WA
I will be making the grille out of the same expanded mesh that I used on the sidepipe heatshields. It should look somewhat similar to the picture link that was posted on here.
I was thinking I may paint the new grille bright pink  ..... They just said I had to make a grille, they didn't mention anything about the colour!!!
03-06-2009, 03:51 AM
NSW
I am wondering if you put it to the engineer / the rego mob; that, if you installed a screen just in front of the radiator. Would that be sufficient. I intend to put one in front of mine to stop rocks and bugs. It will be about 1" in front of the radiator core and will hardly be noticeable.
03-06-2009, 06:07 PM
nsw
Cobra Make, Engine: Homebush fibreglass
No shame in failing, plenty of us do.
I failed on noise and they queried the angle of sight between the driver looking ahead and looking slightly to the left at the speedo! (less than 15 degrees)
Just look on it as another couple of jobs to do, it'll make rego success sweeter!
Wonder what the most bizarre/ridiculous reason for failure is?
03-06-2009, 06:10 PM
nsw
BTW Plums, how did you manage to pass the noise test with your vent holes open?
I found that the noise level from the front of the car was similar to that at the back and had to put plenty of noise mat in the engine compartment to pass, including blocking the vents.
03-07-2009, 04:34 AM
WA
Here is my "Grille", it's not pretty but it should be ok...
Also fitted the vents as required by the examiner.
