Old 06-25-2009, 10:07 PM
Default LS1 wiring diagram
I'm just about to wire up the Dragster and need the wiring diagram to know which wires to pull from the PCM plugs to run power, fans, tacho etc. Also I need to wire in the OBDII port etc.
I used an entire Commodore loom, (dash, BCM, PIM etc.) in my Cobra so it was all just plug and play. Now I need to "cut the fat" in the Dragster, getting rid of all useless wires and plugs....
Plums
Old 06-26-2009, 07:46 PM
Gav's Avatar
Gav Gav is offline
Easy done Bob, I'll ring you!
Powered by Cu
Old 06-28-2009, 04:50 AM
cobbindale's Avatar
Cobra Make, Engine: Classic Revival.
Hi Bob,
Did you get enough info from Gav or do you need more?
Cheers, Dale.
Old 07-04-2009, 08:31 AM
boxhead's Avatar
Hey there Bob, I have diagrams I can email you but not till I get home. (possably the same ones Gav has)
If you still need them I will be back in Oz on the 13th July.
Just let me know.
Cruising in 5th
