09-27-2009, 02:28 AM
NSW
MMM Polished hub carrier!
Hi all,
Thought i would post up some pics of todays work.
I spent the whole day sanding and polishing until my fingers actually started bleeding.
I only got one hub carrier done but i am happy with the result. I am using a 5 spoke wheel, so wanted the hub to look nice since it will be visible.
Has anyone got any recommendations on coatings? It would need to be heat resistant. Im currently planning to leave it how it is, but a clear would make maintenance easier.
Liam
09-27-2009, 03:46 AM
You are gonna hate yourself for polishing those as it's a PITA to keep that way.
For a clear coating try this: http://ppcco.com.au/topcoat_glistenpc.htm
An alternative which looks good is to give the carriers a good sand and remove casting ridges etc.
Give them a coat of POR15 silver which has a high aluminium solids content, sand the POR15 to achieve a perfect serface then follow with a coat of POR15 Stirling Silver. ( same site as above link)
Wear gloves when using POR15 as the only way to get it off your skin is to wait till the skin sheds.
09-27-2009, 03:52 AM
NSW
But it looks cool! I dont think silver paint looks as good, although anything is better than the ugly rough casting.
I was looking at the the Glisten kit on their web site. Im just not sure it will take the heat and brake dust. Mind you they say it can be used on carby's and intake manifolds which can get pretty hot. They are just up the road from me so i might drop in on my way past to work.
Liam
09-27-2009, 03:57 AM
Liam, I have never been disappointed with any POR15 product. The products cannot be compared with any other paint system.
09-27-2009, 05:57 AM
WA
Newspaper dropsheet...
09-27-2009, 06:26 AM
VIC
wow...
that is a mighty effort
LoBelly
09-27-2009, 07:08 AM
Cobra Make, Engine: Butler...488" hi-rise, dry-sump FE s/o w/stacks
ZOOPSEAL might work....it withstands heat good and stays shiny. I've used it all over my engine.
Nice work by the way.
Good Luck.
Russ
09-27-2009, 04:01 PM
NSW
Zedn, I can't resist, too good to pass up - work your butt off? Those Cobra seats getting tight?
Ha, didnt even notice that, must have been the wife
09-27-2009, 10:02 PM
NSW
Liam,
Excuse me if I don't comment on this one. The last time I opened my mouth on one of your Threads saw 90 responses and 2,234 hits in 11 days.
All I'll say is "Looks Good Man,"
Baz
09-27-2009, 10:28 PM
Vic
I just gave mine a good coating of grease, oil and road grim.
Took a good 6 months or so to get the coating just right.
Matches the diff, tranny and sump beautifully.
09-27-2009, 10:33 PM
I love your patience, you must be in less of a hurry to finish your car as I am to finish mine.
Please keep posting pic's, we love great work!
Regards.
Mando
09-27-2009, 11:27 PM
NSW
No, just waiting to move into my new garage so i can paint and reassemble the suspension. I can't spray 2 pack in a unit block, might get some unhappy light headed neighbours!
I am actually in more of a hurry now with the ESC scare (but thats a whole other thread).
Baz, thats ok, those statistics are a good sign for that other thread though.
Liam
09-28-2009, 03:14 AM
NSW
I'm with you Reptyl, it has that more lived in look....
289 FIA Cobras RULE!
09-28-2009, 04:23 AM
NSW
Well that is the only finish that actually gets thicker and stronger with age!
09-28-2009, 11:40 PM
WA
Cobra Make, Engine: G-Force, Ford 5.4 SOHC 3v
Liam,
You must have the patience of a saint.
You have a couple of ways to go -
Chrome: You have done all the expensive time consuming polishing work,
all it needs now is to go in the chroming baths, so get a few quotes.
Powder coating: In a baked hard clear coat.
Anodizing: I believe they can do a clear coat as well.
They will look awesome behind a 5 spoke wheel.
Good Luck.
Harry.
09-29-2009, 01:17 AM
nsw
Cobra Make, Engine: Homebush fibreglass
Por15 are quality products and tough as. I have not however been overly impressed with glisten, given the cost. It seemed to dull down the shine.
09-29-2009, 01:32 AM
NSW
Thanks for the tip, i was leaning towards the glisten. I might look into clear anodizing, i have heard of this used on alloy wheels.
Im still considering just waxing it and leaving it natural. Im thinking that once this car is finished i will enjoy hiding away in the garage with a beer and a microfibre cloth anyhow! Im sure i will regret it!
Liam
09-29-2009, 01:47 AM
VIC
You should also be careful with anything like anodizing or chroming on suspension parts like this. for example chroming on steel can cause hydrogen embritelment making the part weaker. I'm not sure what effect the process may have on aluminum.
Anodizing will harden the surface and protect against corrosion which is probably a good thing but you would have to wonder if it will affect the heat treating of a part like that. Also some castings don't take anodizing well so you may get an inconsistent finish. Hard anodizing may give a slightly yellow color to the aluminium too.
What ever process you do check with the guy doing it and explain what the part is for and find out how it may be affected.
Mike Murphy
Melbourne Australia
