Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 11-02-2009, 06:44 PM
Wbulk's Avatar
Cobra Make, Engine: 66 Cobra
Default Emergency Brake Cable Question
I have the B and B narrowed 9" rear axle with the disc brakes. There is a large spring on the caliper and a small long spring on the cable. Do you use them both or cut the small one off.
Old 11-03-2009, 09:15 AM
Wbulk's Avatar
I found out the answer to the question. The smaller spring on the cable is cut off. You use the one on the caliper.
Old 11-04-2009, 10:00 AM
Wbulk's Avatar
Any suggestions on how to route these cables? They are pretty long.
Old 03-05-2010, 10:59 AM
Cobra Make, Engine: NAF 1965 427 bodied w/Clevland 351 bored 60 over toploader 4 speed White and grey stripes
If cables are too long you can cut and re end cables contact a brake supplier like wildwood and see what they have for shorting cables they may be able to make new cables for you also
