Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 02-16-2012, 11:49 AM
Cobra Make, Engine: B&B, 392 Windsor by Steve Schmidt Racing Engines - lots of chrome. 400 hp
Default Cutting a hole in carpeting
Does anyone know of a way to cut a hole in carpeting that does not ruin the carpeting by unwinding all of the carpet threads? I want to mount my mini fire extinguisher.
Old 02-16-2012, 12:07 PM
mreid's Avatar
Cobra Make, Engine: Kirkham 289 FIA #690, FRPP 427 Boss engine
Use a pencil soldering iron. Push it into the carpet where you want the hole and melt a hole through. Works well on up to 1/2" holes sealing the carpet as you go and can be used on larger holes with a slightly different technique.
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
Old 02-16-2012, 12:35 PM
OK, that sounds very workable. I'll give it a try on a scrap set-up. Thanks!
Jim K.
Old 02-18-2012, 07:13 AM
Seagull81's Avatar
Cobra Make, Engine: FFR3542K, 347 C. I., EFI, T-5, Miata Front Sway Bar, 3 Link, Red with White Stripes
If you need a bigger hole, I think an electrician knockout punch should do it.
Steve
Texas Cobra Club-Seguin
July 2009 FFCars Picture of the Month
FFR3542K, 347, Holley Sniper EFI, T-5, 4 Wheel Discs, 3-Link, Miata Front Sway Bar, Red with White Stripes
Old 02-18-2012, 11:41 AM
beast's Avatar
Cobra Make, Engine: Unique Motorcars, 427 side oiler
A sharp gasket hole punch also works well. Just turn by hand...makes a clean hole. Gary
Old 02-21-2012, 01:40 PM
Thank you, I will give them all consideration as soon as my garage warms up!
Old 02-22-2012, 06:11 AM
Clois Harlan's Avatar
The pencil soldering iron works best for installing screws through carpet. Used that for years. Bigger holes I have been known to take an old paring knife and heat it up to cut around a hole that I had marked out in chalk. No unraveling!!
Clois Harlan
"Let's roll"
"Be part of Something Good
