Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 10-22-2013, 08:01 AM
ndpace's Avatar
Cobra Make, Engine: B&B with Motorsport Crate 302
Default wire routing
I have tried a couple things but they keep failing. how have people routed and stuck their wiring for the front lighting? I had some adhesive fail on the inside of the fender and a wire wrapped around the wheel while driving.
any suggestions would be great
Jim
2020 Shelby GT500
93 Mustang Cobra
66 B&B Cobra
67 Mustang Coupe
63 T-bird Convert
47 Fordor Flathead
01 F350 Crew Cab V10
Old 10-22-2013, 08:15 AM
NFLDMNBB's Avatar
Cobra Make, Engine: B&B, FR302
You can find small square tabs in the electrical department at a hardware store. They have adhesive backs and a lug on the front that a plastic wire tie can be attached to. Mine have been on the car since 2003.
Hope this helps.
Roger
There are two kinds of people - those smart enough to know they don’t know, and those dumb enough to insist they do
Old 10-22-2013, 08:26 AM
ndpace's Avatar
those are what I used and they failed on me. where did you attache them? Mine were inside the fender where it was rough. I am thinking about siliconing them in. that will not affect the fiberglass will it?
2020 Shelby GT500
93 Mustang Cobra
66 B&B Cobra
67 Mustang Coupe
63 T-bird Convert
47 Fordor Flathead
Old 10-22-2013, 08:58 AM
NFLDMNBB's Avatar
You might try to clean the area that you want to attach to with lacquer thinner. Mine are attached to the upper part of the nose section.
Old 10-22-2013, 09:11 AM
ndpace's Avatar
I will try that. it is the rough backside of the fiberglass and I did not want to use anything that might attack the open fiberglass
2020 Shelby GT500
93 Mustang Cobra
66 B&B Cobra
67 Mustang Coupe
63 T-bird Convert
47 Fordor Flathead
Old 10-22-2013, 09:47 AM
NFLDMNBB's Avatar
I can't imagine that the lq would have too much affect on it. I've used it to clean small areas. It dries quick and takes any grease or oil off.
Old 10-22-2013, 03:32 PM
Average Guy
Cobra Make, Engine: red Shell Valley, white stripes
I had trouble getting mine to stick, too. I tried Liquid Nails construction adhesive and it solved the problem. The little plastic blocks have stayed put for over 20 years now. I had some in my caulking gun for another project and elected to give it a try--worked great.
When I said I wanted to be somebody, I probably should have been more specific...
Old 10-23-2013, 06:22 PM
Wbulk's Avatar
Cobra Make, Engine: 66 Cobra
When I was building my car I glassed in some PVC pipe and ran all the front light wiring through it on the right. I then went over the hood hinge and then to the left side. I welded a bracket in the center of the hinge to hold the wiring loom.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
