Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 04-13-2014, 09:20 AM
Wbulk's Avatar
Cobra Make, Engine: 66 Cobra
Default Rattling Mufflers on B&B (and Fixes)
With less than two hundred miles on my car both mufflers rattle when the engine is running. I stuck a small LED flashlight inside to see what is going on. They have a perforated center tube that seems to be the problem. It has spiral perforations in a swirl pattern front to back. Interesting, the perforations on one side face forward, the other side face back.
Has anyone had experience with these. They may be Thrush brand by the description. It looks like the only way to fix them is to cut the mufflers out to get to the ends. Can they be fixed. It looks like the center tube slides.
Thanks.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
