Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 05-02-2014, 01:15 PM
Cobra Make, Engine: B&B Ford FE from Southern Automotive
Default Team III wheels installed on B &B Cobra
Anybody running Team III wheels on a B&B Cobra? If so what wheel width and back spacing are you running. I'm considering 17 inch wheels for this project. Looking at 8 inch width in front and 10.5 inch rear. This installation will be bolt on type wheel with a Ford 5x4.5 bolt pattern. Running Tubular Mustang II front end and narrowed Ford 9 inch 4 link setup in the rear.
Team III has a special package for FFR cars but I don't know if the back spacing will work on a B&B.
Old 05-05-2014, 05:51 AM
lnfletcher's Avatar
Cobra Make, Engine: B&B 427 Stroked Windsor TKO 600 w/3.50 posi 9"
4.5" back spacing 7" and 8". 245/50 in front 295/50 in rear.
Larry's Home Page
Old 05-06-2014, 02:39 PM
Wbulk's Avatar
Cobra Make, Engine: 66 Cobra
I have Team III wheels on my car. In the front I have 7" wheels with 4 1/2" back spacing with 235x60 tires. The outside bulge of the tire is even with the outside lip on the fender. For the rears I have 10" wheels with 5 1/8" back spacing with 295X50 tires. The outside bulge is also just even with the top outside lip of the fender.
While the 295s look good in the rear it is very tight. I don't like the tires sticking out and I had to cut a section of fiberglass out and redo it on left rear inner front wheel well to keep the tire from rubbing. This really depends on how the inner tub was set when the car was built. If I were to do it again I would go with smaller rims in the rear and 275 tires. With a little less back spacing and the smaller tires the chances of rubbing would be less and the smaller tires would be in a little more.
Understand this also depends on your rear axle width. Mine is 55 3/8" axle flange to flange, or 56" outside rotor to outside rotor.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
