Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 02-08-2002, 09:38 AM
jams's Avatar
Cobra Make, Engine: B & B
Default Battery Cable
Hi,
This forum has been a big help!Thanks for all the responses.
What is the best way to run the battery cable from the trunk to the starter?? Should it go through the cockpit, under the car along the frame or any other ideas.
Thanks for your help.
Paul
Old 02-08-2002, 10:10 AM
Ron61's Avatar
Default Re battery cable
I ran mine under the car along the frame and it is held by body clips every six inches so it is easy to remove or work on if I ever need to. I have had it that way for 8 years and no trouble and you can't see it unless you are under the car.
Ron61
Old 02-08-2002, 11:00 AM
BLACKJACK
Guest
Posts: n/a
Default BATTERY CABLE ROUTING
HELLO PAUL,
I USED "0" GAUGE COPPER WELDING CABLE - VERY FLEXIBLE YET VERY HIGH CURRENT CARRYING CAPACITY - YOU DON'T WANT TO SKIMP ON THE CABLE. "SIZE DOES MATTER". I USED SOLDERED-ON COPPER "EYE" FITTINGS ON THE CABLE ENDS. I USED A PROPANE TORCH TO SOLDER THEM. BE SURE TO USE A RESIN CORE SOLDER.
I RAN IT THRU A LENGTH OF 3/4 INCH GALVANIZED ELECTRICAL CONDUIT. I USED (YOU CAN RENT THEM FOR NICKELS) A CONDUIT BENDER TO FORM THE BACK PORTION TO BRING IT UP INTO THE TRUNK. I USED A 3/4" CONDUIT COMPRESSION FITTING ON THE END OF THE CONDUIT AND A 3 INCH ROUND UTILITY BOX COVER ON THE TOP AND THE BOTTOM OF THE TRUNK MATERIAL AND A "JAM" NUT ON TOP AND BOTTOM OF THE ASSEMBLY. IT "AIN'T GOIN NOWWHERE".
I FASTENED THE CONDUIT ALONG THE OUTSIDE OF THE RIGHT HAND MAIN FRAME RAIL WITH CONDUIT "STRAP" CLAMPS ABOUT EVERY 12 INCHES.
THE FRONT END IS A BIT DIFFERENT: I BENT THE CONDUIT UP INTO THE ENGINE BAY ABOUT 6 INCHESS AND TERMINATED IT THERE. THE CABLE CONTINUED ON (ABOUT 12 INCHES) TO THE STARTER WITH OUT THE CONDUIT. I USED ELECTRICAL (NON-HARDENING) RUBBERIZED INSULTING TAPE TO SEAL THE OPENING AROUND THE CABLE AND THE CONDUIT.
THE T.W. CONDUIT IS GALVANIZED INSIDE AND OUT BUT I SPRAYED THE OUTSIDE WITH NON-HARDENING UNDERCOATING FINISH JUST IN CASE - ALSO FOR COSMETIC PURPOSES. WHEN YOU LOOK UNDER THE CAR YOU DON'T EVEN SEE THE CONDUIT.
MY CONCERN WITH "RUNNING THE CABLE BARE" IS BOTH DETERIORATION FROM ROAD SALTS AND OTHER CHEMICALS AND DAMAGE (AS IS IN "SHORTING OUT") FROM FLYING DEBRIS FROM THE ROAD SURFACE. MY SYSTEM IS PROBABLY A LITTLE "ANAL" OR AT LEAST A LITTLE OVERKILL - I GUESS SOME OF THAT COMES FROM SURVIVING 23,000 HOURS PLUS OF FLYING TIME. BUT I ALSO ONLY LIKE TO DO EACH PROJECT ONCE.
IF YOU HAVE ANY QUESTIONS PLEASE E-MAIL OR CALL ME 703-723-7276.
INCIDENTLY: THE CABLE END IN THE TRUNK DOES NOT GO DIRECTLY TO THE BATTERY; IT GOES TO A CONTACT ON THE EMERGENCY CUT-OFF SWITCH JUST BEHIND THE PASSENGERS SEAT. FROM THER IT GOES - ABOUT EIGHT INCHES TO THE BATTERY.
JUST A THOUGHT: FROM THE "BATTERY" SIDE OF THE CUT-OFF SWITCH (BY-PASSING THE CUT-OFF SWITCH) I HAVE A SHORT PIECE (8 INCHES) OF 14 GAGE WIRE WHICH CONNECTS TO AN 8 AMP - IN LINE FUSE - THE WIRE THEN ACCOMPANIES THE BATTERY CABLE INSIDE THE CONDUIT. WHERE IT EXITS THE CONDUIT, IT GOES THRU A SMALL (GROMETTED OF COURSE) HOLE IN THE DASH AND INTO THE COCKPIT. IT ALLOWS ME TO HAVE A "UTILITY CIRCUIT" EVEN WHEN THE CUT-OFF SWITCH IS "OPENED".
MY UTILITY CIRCUIT POWERS AN 8 DAY CLOCK AND A COCKPIT MAP LIGHT. (CERTAINLY NOT ORIGINAL BUT "CORRECT FOR THE PERIOD. I LIBERATED THEM FROM AN F-86). IT ALSO POWERS UNDER DASH CONCEALED AREA LIGHTS AND THE ALARM SYSTEM
AGAIN IF YOU HAVE ANY QUESTIONS PLEASE CALL ME
Y'ALL HAVE A REALLY GREAT DAY,
BLACKJACK
Old 05-14-2002, 07:55 PM
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
OK, I am running my cable. Although I like the conduit idea, it seems like a lot of work and overkill. I purchased the 2 guage Accel kit from Jegs, which I would recommend, it is very easy to work with. I was going to run it along the inside of the frame rail, however, I run into a dead end at the e-brake bracket. What did you guys do? Jams? Ron?
Old 05-14-2002, 08:07 PM
Cobra Make, Engine: B+B 351w #112
I ran mine down the passenger side of the frame then over the edge of the trans tunnel and up the solennoid I have mounted on the firewall. jim
Old 05-15-2002, 07:35 AM
jams's Avatar
I ran my cable through a hole I drilled in the e-brake cable bracket. Be sure to use a grommet. Drill a hole in the best place as not to weaken the e-brake bracket.
Good Luck
Old 08-11-2002, 08:14 PM
Okay, I have the battery cable run back to the rear cowl. Where should I run it into the trunk at?
Old 08-13-2002, 02:47 PM
jams's Avatar
Here are a few pics of the battery cable running into the trunk and into a battery cutoff switch. After the switch it goes around the roll bar support to the battery on the drivers side of the trunk.
Check out the pics below:
http://www.jamswebdesign.com/cobra2/battery.htm
