Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 03-15-2002, 07:24 AM
jams's Avatar
Cobra Make, Engine: B & B
Default Shifter lever suggestions for a Tremec 3550
Hi guys,
My tremec 3550 trans is in but I need a shifter lever. I know they come in all lengths and angles. Does anyone have any suggestions as to which one would fit the best and where to order them?
Thanks for your help.
Old 03-15-2002, 08:20 AM
wicked fast's Avatar
The longest build.....
Cobra Make, Engine: Mid-States, 428 Police Interceptor, TKO 5 speed, Jaguar rearend, Trigos, and Guardsman Blue!!!
Lightbulb look here...
jams,
FinishLine.
Check out the photo in my gallery of Enzo's shifter handle on my TKO.
Wicked Fast
If you were to die tonight, are you 100% sure
that you would go to Heaven ??
www.bluecarministries.com
Old 03-19-2002, 04:09 AM
Cobra Make, Engine: B&B 351W
I have the same problem, I might go to ford and get a stock one for a 93 or 94 mustang $60 let me know if you find anything better.
bsuttonmci@att.net
Old 04-23-2002, 04:39 PM
i just went with the same setup and used a pro 5.0 works great
www.upstatecobras.com
founding member
Old 04-23-2002, 06:01 PM
pbrown's Avatar
Cobra Make, Engine: Franklin Mint 427S/C replica
blubyu2,
What shifter position did you use? I thought the rear position would be too far back for a standard shifter.
Patrick Brown
http://www.uniquecobra.com
Old 04-23-2002, 07:05 PM
No make sure you use the standard furthermost position it will work just fine if you are using a small block ford.
bsuttonmci@att.net
