Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 06-29-2002, 04:38 AM
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
Default Anyone mounted the finishline dual fans?
I picked up a set of the Finishline dual fans from someone online. Probably too soon in my build, but what they heck. Has anyone mounted them on a B&B yet? Where did you mount them?
Old 07-04-2002, 06:57 AM
Cobra Make, Engine: N/A
I mounted mine to the 1" x 2" crossmember that passes right in front of the radiator. I used angle irons to attach to the brackets, and drilled and tapped the crossmember through from the bottom since my body's already on the frame. You may need to redrill mounting holes for the fans on their brackets as the hood hinges come very close. I cheated my fans in about 1" closer in their center to center distance, and acheived marginal clearance to the hinges. Remember to close up with sheetmetal all the openings around the radiator or your fans won't push much through the radiator. I "testfired" mine without shrouding, and almost all the air came out between the front of the hood opening and the radiator.
Never ascribe to malice that which can adequately be explained by inattentiveness.
Old 07-04-2002, 07:31 AM
Turk's Avatar
Send a message via Yahoo to Turk
There has been a great deal of discussion on whether the dual pushers help or hurt the air flow. It is my impression they actually block the air flow and cars with a HD puller fan do a better job of cooling than three of these.
You may want to check into it before investing in two more fans. Unless you are going for the look.
TURK
OBAMA IN in 2012
