Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 08-18-2002, 08:24 PM
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
Default Speedo Cable Routing
How did you guys run your Speedo Cables? I have a T-5 and have the cable from B&B. It seems awefully long. JAMS, one of those magic pictures?
Old 08-19-2002, 07:12 AM
jams's Avatar
Cobra Make, Engine: B & B
You can probably use me as an example of what not to do. The B & B Cable is very long. A picture would not help much. Since the cable was so long I went "up, down and back around." I have a tremec 3550 the cable went along the driver's side frame rail, I think it made a gradual turn around the Bellhousing then up through the "trans tunnel" (if that is the correct term) in the rear of the center portion of the dashboard. It then took another "U" loop around until it reached the speedo.
I had to do it all over again I would look into finding a shorter cable and make a more direct route from the trans along the frame rail up through the floor and into the speedo. It is something you just need to play with and make sure you don't have any tight drastic turns.
I am sure someone else has a better idea.
