09-06-2002, 09:38 AM
Also need help with belts?
I want to put a 4 or 5 point system in my b&b and was just wondering what belts and how most guys are mounting them? any pics would be great
Greg
09-06-2002, 09:22 PM
IL
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Come on, someone help Greg and I and others out here.
Tom
09-06-2002, 09:29 PM
Mi
Guys,
We sell and use M&R belts, always putting in four points, on occasion 5 points for required sanction tracks, but... I have no idea how you would mount them in a B&B. Sorry, wish I could help.
Richmond, Simpson, etc. are all good belts.
DV
09-06-2002, 11:00 PM
Blubyu2:
Send me your address, and I will send you photo's and drawings.
Jerry2
09-07-2002, 04:31 AM
IL
Send me pics at tboyce@windycitycobras.com.
Tom
09-09-2002, 09:38 AM
Jerry e-mail is yanksgp@acmenet.net any help would be great thanks..
09-09-2002, 10:30 AM
Jerry,
I'd be interested in the info. as well. My e-mail jpilewis@aol.com
Thanks for the help.
Jon Lewis
09-09-2002, 03:09 PM
I have a Midstates that I want to put 5 point harnesses in. If you don't mind, I'd be interested in any information as well. Thanks Richard rlucero@guidant.com
09-30-2002, 10:31 AM
Location: Right in the middle of the beautiful Texas Hill Country - Boerne, Texas,
Does anyone have suggestions, steps, and/or photos to put 5 point harness in a B&B after the body and interior is installed?
thanks
blake - wishing I would've done it before.
"They're lining up on both sides of the ocean..
and nobody's willing to compromise
in the search for the smoking gun..."
"Charlie Don't Surf!"
09-30-2002, 11:03 AM
Cal
I would recommend putting in the submarine strap if you are installing the shoulder harnesses. That belt keeps the buckle assembly from getting pulled up into your ribs when you cinch down the shoulder straps.
11-02-2002, 09:24 PM
TTT....
I'm also trying to figure this one out....On T-3's website they are adding a piece of square tubing to the outside frame rail. The only problem with this is that I already have my body on. Any help would be appreciated
11-03-2002, 01:11 AM
IL
Wow, T-3 did a lot of work on their site since I last visited 3 weeks ago. I think the tube addition is a T-3 special touch, I would love to know what others have done to install the belts.
Tom
08-07-2005, 11:44 AM
NJ
Cobra Make, Engine: B & B
Anyone have any seatbelt harness pictures?
Did you need to use Bezels for the sholder straps?
Do you use a harness for everyday driving? Just curious!!!
08-07-2005, 12:03 PM
NJ
Any preference between V or individual harness?
08-07-2005, 08:36 PM
IL
Cobra Make, Engine: B&B, 351 W, TREMEC 600
I have installed a 5 point in my B&B and it went real well. I used Simpson's. I wanted the Y harness but they discontinued it. I bolted the submarine belt to the steel plate under the seat with the belt bracket sticking out enough to allow adjustment. The shoulder harnesses bolt through the first frame member behind the fiberglass behind the seats. The only problem is getting the angle right as it comes through the fiberglass and over the seats.
I chose not to use a V-harness because I wanted to finish the holes into the passenger compartment with bezels.
I can get pictures easily.
Rob
08-07-2005, 08:47 PM
IL
Jams, I do not have pictures. I know the newer frames have better mount locations to facilitate a better angle of the lap belt eye bolts (there is a welded pad inboard of the transmission tunnel tubes). Just go through the bulkhead and to an eyebolt mounted to the thick tube that makes the shelf behind the seats. BTW, you will probably need a right angle bit if you are doing it with the body on. I used bezels from finishline.
08-08-2005, 07:01 AM
NJ
Thanks for your input guys.
Rob V. any pics would be appreciated.
08-08-2005, 07:22 AM
NJ
What is the best length 50" 55" 60"???
08-08-2005, 06:46 PM
IL
